[mapguide-users] RE: Clear Selection
RichBauer
rdbauer at gmail.com
Mon Jul 2 08:06:33 EDT 2007
It is 1.1.0. That is probably why. I was not wanting to use 1.2 RC for a
production implementation. Once the final version of 1.2 is out, I will use
that. Thanks.
Rich
Chris Claydon wrote:
> This issue is described in trac ticket 37...
> http://trac.osgeo.org/mapguide/ticket/37
> It was fixed about three months ago. Which version of MapGuide are you
> seeing this with?
> Chris.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of RichBauer
> Sent: June 29, 2007 2:18 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Clear Selection
> Has anyone experienced the problem of when say a parcel (polygon) is
> selected
> and the properties display just fine and then you use the "Clear
> Selection"
> command from the right-click menu, the highlighting clears, but the
> properties window does not clear? If so, is there a way to fix it? It
> is
> not a big deal, just for cleanliness. Thanks.
> Rich
> http://www.nabble.com/Clear-Selection-tf4001770s16610.html#a11366536
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Clear-Selection-tf4001770s16610.html#a11392720
