[mapguide-users] Re: [fdo-users] FDO build_thirdparty
Ray Holtz ray at rayholtz.com
Thu Jul 5 16:09:29 EDT 2007
I am running as root.
Traian Stanev wrote:
> Are you running as root? May be the script doesn't have enough
> permissions to put stuff under /usr/local?
> Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Ray Holtz
> Sent: Thursday, July 05, 2007 1:55 PM
> To: FDO Users Mail List
> Cc: MapGuide Users Mail List
> Subject: Re: [fdo-users] FDO build_thirdparty
> I ran the build script under Thirdparty\apache and it did not give me
> any errors.  The following is the last few lines:
> make -C Utils locale
> make[2]: Entering directory
> `/usr/local/maptemp/OpenSource_FDO/Thirdparty/apache/xml-xalan/c/src/xal
> anc/Utils'
> ../../../bin/MsgCreator
> /usr/local/maptemp/OpenSource_FDO/Thirdparty/apache/xml-xalan/c/src/xala
> nc/NLS/en_US/XalanMsg_en_US.xlf
> -TYPE INMEM -LOCALE en_US
> make -C XalanMsgLib
> make[3]: Entering directory
> anc/Utils/XalanMsgLib'
> g++ -O2 -DNDEBUG      -fno-elide-constructors -Wall -fPIC -DLINUX
> -D_REENTRANT -DXALAN_INMEM_MSG_LOADER -c -I/usr/local/maptem
> -I/usr/local/maptemp/OpenSource_FDO/Thirdparty/apache/xml-xalan/c/includ
> e
> -I../../../../nls/include
> -I/usr/local/maptemp/OpenSource_FDO/Thirdparty/apache/xml-xerces/c/src/
> -I/usr/local/maptemp/OpenSource_FDO/Thirdparty/apache/xml-xerces/c/inclu
> de/xercesc
> de/
>   -o ../../../../obj/XalanMsgLib.o
> nc/Utils/XalanMsgLib/XalanMsgLib.cpp
> -Wl,-soname,libxalanMsg.so.17 -DLINUX -shared -fPIC   -lm  -lpthread
> -L/usr/local/maptemp/OpenSource_FDO/Thirdparty/apache/xml-xerces/c/lib
> -lxerces-c   ../../../../obj/XalanMsgLib.o -o
> ../../../../lib/libxalanMsg.so.17.0
> ln -fs libxalanMsg.so.17.0 ../../../../lib/libxalanMsg.so
> ln -fs libxalanMsg.so.17.0 ../../../../lib/libxalanMsg.so.17
> make[3]: Leaving directory
> make[2]: Leaving directory
> anc/Utils'
> make[1]: Leaving directory
> anc'
> Thanks!
> Greg Boone wrote:
>> Run the 'build' script under '...\Thirdparty\apache' and let me know
>> what the errors are.
>>    cd apache
>>    ./build
>> Greg
>> Sent: Wednesday, July 04, 2007 12:14 PM
>> To: MapGuide Users Mail List; fdo-users at lists.osgeo.org
>> Subject: [fdo-users] FDO build_thirdparty
>> Hi all, Sorry for the doublepost on both lists, but I am almost
> pulling
>> my hair out over this install.
>> I am trying to setup Mapguide 1.1 on an Ubuntu 6.06 LTS server. I have
>> installed the aptinstaller fine.  I am working on the FDO now.  I get
>> stuck with the build_thirdparty.sh script.  It ends with the following
>> lines:
>> `/usr/local/maptemp/OpenSource_FDO/Thirdparty/GDAL1.3/src/apps'
>> make[1]: Entering directory
>> `/usr/local/maptemp/OpenSource_FDO/Thirdparty'
>> make[2]: Nothing to be done for `install-exec-am'.
>> /bin/sh ../mkinstalldirs /usr/local/fdo-3.2.0/lib
>>   /usr/bin/install -c -m 644
> ./apache/xml-xalan/c/lib/libxalan-c.so.17.0
>> /usr/local/fdo-3.2.0/lib/apache/xml-xalan/c/lib/libxalan-c.so.17.0
>> /usr/bin/install: cannot create regular file
>> `/usr/local/fdo-3.2.0/lib/apache/xml-xalan/c/lib/libxalan-c.so.17.0':
> No
>> such file or directory
>> ./apache/xml-xalan/c/lib/libxalanMsg.so.17.0
>> /usr/local/fdo-3.2.0/lib/apache/xml-xalan/c/lib/libxalanMsg.so.17.0
>> `/usr/local/fdo-3.2.0/lib/apache/xml-xalan/c/lib/libxalanMsg.so.17.0':
>> No such file or directory
>> ./apache/xml-xerces/c/lib/libxerces-c.so.25.0
>> /usr/local/fdo-3.2.0/lib/apache/xml-xerces/c/lib/libxerces-c.so.25.0
> `/usr/local/fdo-3.2.0/lib/apache/xml-xerces/c/lib/libxerces-c.so.25.0':
>> ./GDAL1.3/linux/lib/optimized/libgdal.so.1.9.0
>> /usr/local/fdo-3.2.0/lib/GDAL1.3/linux/lib/optimized/libgdal.so.1.9.0
> `/usr/local/fdo-3.2.0/lib/GDAL1.3/linux/lib/optimized/libgdal.so.1.9.0':
>> make[2]: *** [install-thdlibDATA] Error 1
>> make[1]: *** [install-am] Error 2
>> make: *** [install-recursive] Error 1
>> It is trying to do something with
> /usr/local/fdo-3.2.0/lib/apache/......
>>   but there is nothing under the /usr/local/fdo-3.2.0/lib directory.
> it
>> is empty.  Then it fails with the makes.  Is there something that I am
>> missing in doing these?
>> Thanks for your help!
>> Ray
