[mapguide-users] SQL Server 2005 ODBC not working with MGOS 1.2 RC2
Ismael Cams
mapguide2007 at gmail.com
Sun Jul 8 15:12:32 EDT 2007
Hello,
I try to set up an ODBC connection with SQL Server. Although the connection
is indicated as succesfull, there are no tables showed. When looking into
the MGOS server log file the following error message is shown:
Error: An exception occurred in FDO component.
Invalid length 0 for column type VARCHAR, must be > 0
StackTrace:
- MgFeatureServiceHandler.ProcessOperation line 83 file
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpDescribeSchemaAsXml.Execute line 107 file
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\feature\OpDescribeSchemaAsXml.cpp
- MgServerDescribeSchema.DescribeSchema line 500 file
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
- MgServerDescribeSchema.ExecuteDescribeSchema line 173 file
Has anyone succeeded in getting a ODBC connection to SQL Server 2005 with
MGOS 1.2 (I have tried both with the beta version and RC2) ?
Kind regards,
Ismaël
View this message in context: http://www.nabble.com/SQL-Server-2005-ODBC-not-working-with-MGOS-1.2-RC2-tf4045596s16610.html#a11491743
