[mapguide-users] How can we make the changes stored in the map in programming methods ?
David Hequet david.hequet at free.fr
Wed Jul 11 05:34:18 EDT 2007
Are you trying to the change without using the viewer? or before the viewer
loads?
Here is what the viewer do when loading :
1. Initialize web tier with an ini file.
2. Connect to the site.
3. Instantiate an MgMap object.
4. Call MgMap.Create to actually create it.
5. Save the MgMap object to your session with MgMap.Save.
then you can use MgMap.open("mymap")
Here is the code to simulate this:
MapGuideApi.MgInitializeWebTier(@"C:\yourpath\WebServerExtensions\www\webconfig.ini");
    MgUserInformation userInfo = new MgUserInformation("Anonymous", "");
    MgSite site = new MgSite();
    site.Open(userInfo);
    String sessionId = site.CreateSession();
    //Associate a session ID with the MgSiteConnection Object
    MgUserInformation userInfo_new = new MgUserInformation(sessionId);
    MgSiteConnection siteConnection = new MgSiteConnection();
    siteConnection.Open(userInfo_new);
    MgResourceService resourceSrvc =
(MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
    MgMap map = new MgMap();
    MgResourceIdentifier resId = new
MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
    String mapName = resId.GetName();
    map.Create(resourceSrvc, resId, mapName);
    MgResourceIdentifier mapStateId = new MgResourceIdentifier("Session:" +
sessionId + "//" + mapName + "." + MgResourceType.Map);
    map.Save(resourceSrvc, mapStateId);
    Response.Write("Done. The map name is " + map.GetName());
about using Administrator insteed of Anonymous, i think you'r right.
Tsai Chih-Cheng wrote:
> Hi David:
> Thank you for your reply.
> I try it referenced the Developer's Guide Version 1.2RC2.
> And I modified my code in your way.
> Then I got this exception :
> OSGeo.MapGuide.MgUnclassifiedException: An unclassified exception
> occurred.
> Error points to the first line :
>     MgUserInformation userInfo = new MgUserInformation(mgSessionId);
>     siteConnection.Open(userInfo);
> I gather that in order to make changes permanent should be logined in
> Administrator.
> The codes look like this :
> MgUserInformation userInfo = new MgUserInformation("Administrator",
> "admin");
> //Create a MgResourceService
> MgResourceService resourceService = siteConnection.CreateService(
> MgServiceType.ResourceService ) as MgResourceService;
> And I got another exception :
> OSGeo.MapGuide.MgInvalidArgumentException: Invalid argument(s):
> [0] = " "
> The string cannot be empty.
> Error points to the first line:
> // Open the map
> map.Open(resourceService, "Sheboygan");
> So I refer to the developer's Guide, and created a session in this way :
> MgSite site = siteConnection.GetSite();
> string sessionID = site.CreateSession();
> userInfo.SetMgSessionId(sessionID);
> I use this session to create a MgResourceService to do some modifications.
> But I get confusion in how to save the map.
> I try 3 save methods, but I still got some error exceptions.
> Could you provide me some specific method in how to create & save map
> status
> permanently ?
> Or, could you give me a complete code to demonstrate how to manipulate and
> modify the data in the Library:// ?
> Thank you for your help.
> patrick
> On 7/9/07, David Hequet <david.hequet at free.fr> wrote:
>> To make changes permanent you have to work in Library repository insteed
>> of
>> Session repository,
>> here is a php sample, after a modification, we save the layer :
>> IN SESSION:
>> // modification here..
>> $byteSource = new
>> MgByteSource($layerDefinition,strlen($layerDefinition));
>> $byteSource->SetMimeType(MgMimeType::Xml);
>> $resourceID = new
>> MgResourceIdentifier("Session:$mgSessionId//$layerName.LayerDefinition");
>> $resourceService->SetResource($resourceID,$byteSource->GetReader(),
>> null);
>> PERMANENT:
>> // modification here...
>> $byteSource = new MgByteSource($layerDefinition,
>> $resourceId =new
>> MgResourceIdentifier("Library://LayerName.LayerDefinition");
>> $resourceService->SetResource($resourceId, $byteSource->GetReader(),
>> null);
>> Just do it :)
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/How-can-we-make-the-changes-stored-in-the-map-in-programming-methods---tf4044102s16610.html#a11537116
