[mapguide-users] SQL Server 2005 & OSGeo.ODBC 3.2 Features
-Broken?
Ismael Cams
mapguide2007 at gmail.com
Sun Jul 15 07:22:34 EDT 2007
Which driver are you using ? I had the same problem with the native SQL
driver. The problem is solved by using the SQL Server driver.
WCT wrote:
> MGOS 1.2.0 RC1 / ODBC 3.2 Provider, WIN32
> I am using Mapguide Studio 2007 1.0.0.17864. I am trying to create a Data
> Connection to SQL Server 2005 database using ODBC provider. I can
> successfully connect to the database but clicking the "Show Tables" button
> returns no results. None of the tables have any features data (I am trying
> to use the data for feature joins w/ existing features). I see errors in
> the server log:
> <2007-07-13T12:56:44> Administrator
> Error: An exception occurred in FDO component.
> Invalid length 0 for column type VARCHAR, must be > 0
> StackTrace:
> - MgFeatureServiceHandler.ProcessOperation line 83 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
> - MgOpDescribeSchemaAsXml.Execute line 107 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src\services\feature\OpDescribeSchemaAsXml.cpp
> - MgServerDescribeSchema.DescribeSchema line 500 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
> - MgServerDescribeSchema.ExecuteDescribeSchema line 173 file
> Has anyone had success with this setup? My providers.xml looks proper:
> <FeatureProvider>
> <Name>OSGeo.ODBC.3.2</Name>
> <DisplayName>OSGeo FDO Provider for ODBC</DisplayName>
> <Description>Read/write access to ODBC-based data store. Supports XYZ
> point features.</Description>
> <IsManaged>False</IsManaged>
> <Version>3.2.2.0</Version>
> <FeatureDataObjectsVersion>3.2.2.0</FeatureDataObjectsVersion>
> <LibraryPath>C:\Program
> Files\MapGuideOpenSource\Server\Bin\FDO\ODBCProvider.dll</LibraryPath>
> </FeatureProvider>
View this message in context: http://www.nabble.com/SQL-Server-2005---OSGeo.ODBC-3.2-Features--Broken--tf4076323s16610.html#a11601509
