[mapguide-users] MapAgent.exe persists after browser close
Rock Beans rockbeans at gmail.com
Tue Jul 17 09:29:45 EDT 2007
Make sure your using the FastCGI for the PHP and FCGI extentions within IIS.
This allows the php-cgi.exe and mapagent.exe to be run as a process vs. a
new instance per process.
The Rock
On 7/17/07, nicholda <nicholda at talgov.com> wrote:
> Thanks for your response Kenneth,
> Our issue seems to be that the functionality we are trying to provide
> winds
> up creating additional MapAgent.exe processes as a result of a successful
> run.  Essentially we are opening the map, creating serveral new layers
> with
> 1 to many points on each one, pushing the layers into the map, then
> storing
> the map back in the repository with the users sesssion.
> The report looks great.  However, when the map refreshes, it creates a new
> MapAgent.exe process.  So, if we create 40 reports, we reach max class
> processes reached and then have to manually go in and start killing
> processes / restarting MapGuide.
> The code we are using was taken / modified from the development guide; I
> can
> tell you that we are not doing anything explicity to close any of the
> resource or feature services created; is there a chance that a simple
> featureService.close() or something related could keep this from
> happening?
> Or does the creation of new layers on the fly necessitate the creation of
> a
> new MapAgent.exe process and our only option includes kicking the timeout
> down from 120 seconds.
> Any and all insight is appreciated.
> Thanks,
> David
> Kenneth, GEOGRAF A/S wrote:
> > I belive that MapAgent.exe is supposed to keep running.
> > IIS/Apache will load/unload fastCGI, to avoid continously reloading
> > MapAgent.exe.
> > If you are using WinXP IIS, you are likely refering to the IIS
> > connection limit on WinXP.
> > You can increase the number of allowed connections to 40.
> > Instructions can be found here:
> > http://weblogs.asp.net/cazzu/archive/2003/10/10/31476.aspx
> > Regards, Kenneth, GEOGRAF A/S
> > nicholda skrev:
> >> Hi All,
> >>   I am having trouble with MapAgent.exe, after closing the web browser
> >> MapAgent.exe is still running in the background.  Eventually I hit the
> >> max
> >> number of connections and can't make another connection until I
> manually
> >> end
> >> the MapAgent processes running in the background.  I am running MGOS
> 1.2.
> >> Could someone point me in the right direction for resolving this issue.
> >> Thanks,
> >> David
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/MapAgent.exe-persists-after-browser-close-tf4090604s16610.html#a11648611
> Sent from the MapGuide Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070717/65e7cf55/attachment.html
