[mapguide-users] MapAgent.exe persists after browser close
Rock Beans
rockbeans at gmail.com
Tue Jul 17 11:05:22 EDT 2007
I am sorry, I have no clue about Apache on Windows and how it handles the
FastCGI dll. I know on Linux this is not an issue. I do know however there
is some registry information that pertains to max servers and other settings
when used against IIS.
HKEY_LOCAL_MACHINE\SOFTWARE\FASTCGI
The Rock
On 7/17/07, Scott, Brian <ScottB at talgov.com> wrote:
> Hi The Rock -
> Great name. We are running Apache, not IIS. Below is the fastcgi
> configuration section from the httpd.conf file.
> FastCgiConfig -idle-timeout 120 -startDelay 1 -minProcesses 4
> -maxClassProcesses 40 -multiThreshold 100 -singleThreshold 100 -killInterval
> 600
> FastCgiServer "C:/Program
> Files/MapGuideOpenSource/WebServerExtensions/php/php-cgi.exe" -processes 4
> -idle-timeout 120 -initial-env PHP_FCGI_MAX_REQUESTS=500 -initial-env
> PHP_FCGI_CHILDREN=1
> #Start PHP FastCGI config
> ScriptAlias /php/ "C:/Program
> Files/MapGuideOpenSource/WebServerExtensions/php/"
> <Directory "C:/Program Files/MapGuideOpenSource/WebServerExtensions/php">
> Options ExecCGI
> AddHandler fastcgi-script exe
> </Directory>
> Action application/x-httpd-php5 "/php/php-cgi.exe"
> AddType application/x-httpd-php5 .php
> #End PHP FastCGI Config
> #Start PHP Config
> #ScriptAlias /php/ "C:/Program
> #Action application/x-httpd-php "/php/php-cgi.exe"
> #AddType application/x-httpd-php .php
> #End PHP Config
> I'm not too hip on FastCGI configuration, is there a mechanism to run as a
> process instead of an instance per process by modifying this configuration?
> Thanks for your help.
> brian
> -----Original Message-----
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org]*On Behalf Of *Rock Beans
> *Sent:* Tuesday, July 17, 2007 9:30 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] MapAgent.exe persists after browser close
> Make sure your using the FastCGI for the PHP and FCGI extentions within
> IIS. This allows the php-cgi.exe and mapagent.exe to be run as a process
> vs. a new instance per process.
> The Rock
> On 7/17/07, nicholda <nicholda at talgov.com> wrote:
> > Thanks for your response Kenneth,
> > Our issue seems to be that the functionality we are trying to provide
> > winds
> > up creating additional MapAgent.exe processes as a result of a
> > successful
> > run. Essentially we are opening the map, creating serveral new layers
> > with
> > 1 to many points on each one, pushing the layers into the map, then
> > storing
> > the map back in the repository with the users sesssion.
> > The report looks great. However, when the map refreshes, it creates a
> > new
> > MapAgent.exe process. So, if we create 40 reports, we reach max class
> > processes reached and then have to manually go in and start killing
> > processes / restarting MapGuide.
> > The code we are using was taken / modified from the development guide; I
> > can
> > tell you that we are not doing anything explicity to close any of the
> > resource or feature services created; is there a chance that a simple
> > featureService.close() or something related could keep this from
> > happening?
> > Or does the creation of new layers on the fly necessitate the creation
> > of a
> > new MapAgent.exe process and our only option includes kicking the
> > timeout
> > down from 120 seconds.
> > Any and all insight is appreciated.
> > Thanks,
> > David
> > Kenneth, GEOGRAF A/S wrote:
> > > I belive that MapAgent.exe is supposed to keep running.
> > > IIS/Apache will load/unload fastCGI, to avoid continously reloading
> > > MapAgent.exe .
> > > If you are using WinXP IIS, you are likely refering to the IIS
> > > connection limit on WinXP.
> > > You can increase the number of allowed connections to 40.
> > > Instructions can be found here:
> > > http://weblogs.asp.net/cazzu/archive/2003/10/10/31476.aspx
> > > Regards, Kenneth, GEOGRAF A/S
> > > nicholda skrev:
> > >> Hi All,
> > >> I am having trouble with MapAgent.exe, after closing the web
> > browser
> > >> MapAgent.exe is still running in the background. Eventually I hit
> > the
> > >> max
> > >> number of connections and can't make another connection until I
> > manually
> > >> end
> > >> the MapAgent processes running in the background. I am running MGOS
> > 1.2.
> > >> Could someone point me in the right direction for resolving this
> > issue.
> > >> Thanks,
> > >> David
> > > _______________________________________________
> > > mapguide-users mailing list
> > > mapguide-users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> > View this message in context:
> > http://www.nabble.com/MapAgent.exe-persists-after-browser-close-tf4090604s16610.html#a11648611
> > Sent from the MapGuide Users mailing list archive at Nabble.com.
> This footnote confirms that this email message has been scanned by
> PineApp Mail-SeCure for the presence of malicious code, vandals & computer
> viruses.
> viruses.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070717/21dd7ae0/attachment.html
