[mapguide-users] MGOS server harware & bandwidth
Trevor Wekel
trevor.wekel at autodesk.com
Fri Jul 20 12:46:23 EDT 2007
Hi Jorge,
I have tried using MGOS over a 1Mbit "home" connection. Personally, I
think it is too slow and the user experience is disappointing. I would
suggest starting at 10Mbit/s. If you are using tiled maps, a single CPU
can serve between 50 and 200 tiles per second. Assuming each tile is
10kbytes, the burst traffic rates will be between 5Mbit/sec and
20Mbit/sec.
Just as a side note, under "lab" conditions with a quad core Intel Core
2 box I have been able to saturate a 100Mbit/s Ethernet line using
pre-generated tiles.
MapGuide interactivity is quite dependant on burst rates. From what I
have heard, "unmetered" bandwidth plans are often oversubscribed. Even
you have a 10Mbit plan, you may never be able to obtain that rate if
there are a 100 other sites sharing the same pipe. If you are looking
to host somewhere, ask your ISP what you can realistically expect as a
burst rate.
Thanks,
Trevor
Sent: Friday, July 20, 2007 9:06 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] MGOS server harware & bandwidth
Hi list
I would like to know what kind of hardware are you using as server and
the bandwith recomended.
Just to have an idea...
Lic. Jorge Rubio
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070720/381e0697/attachment.html
