[mapguide-users] Attaching DWG's
Jackie Ng
jackie.ng at aecsystems.com.au
Sun Jul 22 22:35:29 EDT 2007
Hi there,
Only MapGuide Studio can load DWGs directly. Web Studio does not have DETE
or similar component (the component that lets you load DWGs)
Web Studio can only create SDF and SHP feature sources. If you want to
create other feature sources, you have to create a feature source document
by hand and load it via mapagent.
- Jackie
b0ris55 wrote:
> Hello,
> I have just installed Mapguide Open Source and I've been playing with
> examples and successfully modified some code and everything is great. The
> issue comes with loading my own DWG and DWF files through web studio. I
> have read numerous white papers and documentation but for the life of me I
> can't figure out how to display the DWF file. Even the MGOS mentions the
> ability to load DWG files but even through Web Studio I can only see SDF
> and SHP as valid Data Types. I would prefer to do this without Mapguide
> Studio as there might be a batch of files and it would be nice if the
> server could just pick them up in the folder. Any help with direction on
> showing my DWF or DWG files in the dfwviewer.php would be great.
> Thanks
View this message in context: http://www.nabble.com/Attaching-DWG%27s-tf4123536s16610.html#a11737067
