[mapguide-users] RE: OGR and MGOS
Rahul
unicorn_admirer at yahoo.com
Wed Jul 25 23:12:14 EDT 2007
Hi ,
I think you check your connection string ,it should be--
POSTGIS
DataSource -----PG: host=xxxx port=xxxx dbname=xxxx user= xxx password=xxx
ReadOnly--------FALSE
same kind of setting you can try for the MySQL.
DataSource -----PG:dbname=xxxx,user= xxx,password=xxx,host=xxxx,port=xxxx
I think OGR 3.2 doesn't work properly with MGOS 1.1 so try MGOS 1.2.0 with FDO 3.2.0.
Cheers
Max !!
nicholda <nicholda at talgov.com> wrote:
I have not tried this with MySql. The problems that was experiencing were
with PostGis. I resolved it by trying the different OGR's available. I have
attached the one that I am currently using for PostGis. I hope this helps.
Below is also the modifications that need to be made to the Providers.xml.
David
OSGeo.OGRProvider.3.2
FDO Provider for OGR
Access to OGR data sources
False
3.2.0.0
3.2.0.0
C:\Program
Files\MapGuideOpenSource\Server\Bin\FDO\OGRProvider.dll
Dhirendra Kumar wrote:
> Hi Nicholda,
> I am also using MGOS 1.1 and Mapguide Studio 07, and OGR 3.2 and i can see
> Datasource and Readonly property, but i can't establish connection with
> MySQL Database. you have any idea about this then help me pls. i enter in
> connection string in datasource is
> MYSQL:westholland,user=root,password=psv9570,port=3306, but it is not
> working. help me.
> Regards,
> Dhirendra Kumar
> nicholda wrote:
>> I am also using MGOS 1.1 and Mapguide Studio 07 6.5. I get a successful
>> connection, but when I try to create a new layer from Postgres. I get
>> the attached error message.
>> Traian Stanev wrote:
>>> I've seen that happen with some builds of the provider -- Studio does
>>> not display the connection properties. What version of MapGuide are you
>>> using?
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rahul
>>> Sent: Wednesday, May 16, 2007 3:05 AM
>>> To: MapGuide Users Mail List
>>> Subject: RE: [mapguide-users] OGR and MGOS
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://www.nabble.com/file/p10663767/Error.JPG
http://www.nabble.com/file/p11781363/OGRProvider.dll OGRProvider.dll
View this message in context: http://www.nabble.com/OGR-and-MGOS-tf3728865s16610.html#a11781363
Be a better Heartthrob. Get better relationship answers from someone who knows.
Yahoo! Answers - Check it out.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070725/12b743de/attachment.html
