[mapguide-users] Selection problem with map stored in session
repository
Ismael Cams
mapguide2007 at gmail.com
Thu Jul 26 08:58:34 EDT 2007
I have following situation:
1. I build dynamically two weblayouts in a session. One is containing a
legend, the other one is only containing the zoom control.
2. The weblayouts refer to the same mapdefinition that is also build in a
session.
3. The mapdefinition is referring to a point layer (sessionlayer)
4. Making a selection in the weblayout without legend works fine.
5. Making a selection in the weblayout with legend does not work correctly.
I have to click above the point to actually make the selection.
6. When I minimize the legend frame (by using the arrow in the webbrowser)
the selection suddenly works correctly. Also when I disable the legend in
the first layout this is also working fine.
7. When I create the same scenario with Studio I do not encounter the
problem (selection is working without problems).
I believe it has something to do with using the same session, but I do not
have a clue where to look after. Can someone give me hints about what could
be the problem ?
Kind regards,
Ismaël
View this message in context: http://www.nabble.com/Selection-problem-with-map-stored-in-session-repository-tf4151469s16610.html#a11809953
