[mapguide-users] Symbols rotation and colors
Rich Bauer rdbauer at gmail.com
Fri Jul 27 08:39:23 EDT 2007
It sound like you what to use themes.   If you use Studio, then that it
fairly easy.  Once you have the feature source and layer defined, select
"Theme >>" under the style for the scale range and input your filter
expression.  If you want to use only code, that is beyond me.  Hope it
helps.
Rich
A H wrote:
> hello, i'm new here.
> i'm using MGOS 1.1 on ASP.net. i'm trying to build an AVL system that shows
> vehicle positions and its tracks (line). currently i managed to display one
> unit with it tracks, using the Sheboygan address and parcel samples.
> the problem is to display more than one unit of vehicle, and each have
> different color codes and degree of rotation (the symbol's rotation). afaik
> the layer definitions will stay after we created it? can i plot more than
> one unit with different color and rotation on the same layer?
> my steps to create the layer now:
> - create class definition
> - create feature schema
> - create feature source
> - load a XML templ for the content
> - create the layer
> - insert command to update feature (with coordinates, names etc.)
> - display layer
> i tried to provide color during the insert command. is it possible?
> if not, do i have to create different layers for each units?
