[mapguide-users] FYI Properties Pane Rounding
RichBauer rdbauer at gmail.com
Fri Jul 27 16:11:35 EDT 2007
FYI
I have searched the forum and have not been able to find the answer to the
question of "how to round the properties pane numbers".  Therefore, I did it
myself and will post the code for everyone to enjoy.
C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\viewerfiles\propertyctrl.templ
under
function SetProperties(count, properties) {
change:
for(var i=0; i < properties.length; i++)
            if(isNaN(properties[i].value) == true)
	    code += '<tr class="GridCell"><td>&nbsp;' + properties[i].name +
'</td><td></td><td>' + properties[i].value + '</td></tr>';
to
	    else
	    var propValue;
	    propValue = properties[i].value;
	    propValue = Math.round(propValue);
'</td><td></td><td>' + propValue + '</td></tr>';
Hope it helps someone in the future.
Rich
P.S.  I am using MGOS 1.1 and when you upgrade, you will have to modify the
file again.
View this message in context: http://www.nabble.com/FYI-Properties-Pane-Rounding-tf4159916s16610.html#a11835931
