[mapguide-users] Solve problem MySQL Polygon Selection
Kenneth, GEOGRAF A/S
ks at geograf.dk
Mon Jul 30 10:28:12 EDT 2007
As someone else mentioned, the selection problem is a known bug in the
MySQL provider.
You have the following options:
1. Wait until someone fixes the problem.
2. Download source and fix it yourself (or perhaps pay someone to do it)
3. Use another provider
If you MUST use a "real" database, I can only suggest Oracle (you have
tried the others).
Are there any reason that you cannot use SDF files?
Regards, Kenneth, GEOGRAF A/S
Dhirendra Kumar skrev:
> Hi All,
> Sorry for repeating this qustion. I tested MS SQL server, MySQL,
> Postgresql/postGIS and i got result MySQL performance is better in compare
> of all, but problem in polygon selection. I want to know that, no way to
> solve this polygon selection problem ? :(
> PROBLEM:- When i select some polygon then near polygon get highlighted in
> place of current selection.
> If anyone have idea or suggestion then please help me. Thankyou in Advance.
> Regards,
> Dhirendra Kumar
