[mapguide-users] Vista and Mapguide Server
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Jul 30 10:37:00 EDT 2007
There is a plugable module for Apache that will run .Net with the Mono
engine.
I belive that others are using PHP for development.
You will probably not get integrated debugging on an Apache server from
Visual Studio.
So: yes and no.
Regards, Kenneth, GEOGRAF A/S
Ivan Milicevic skrev:
> I don't get it. Is it possible to have development on .NET and using
> apache server?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin
> Morrison
> Sent: Monday, July 30, 2007 3:58 PM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] Vista and Mapguide Server
> Use different ports...eg IIS on port 80 and Mapguide on 8008.
> Martin
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ivan
> Milicevic
> Sent: Monday, July 30, 2007 9:55 AM
> Is it possible to hve IIS and Apache on Vista? I can not afford removing
> IIS because of many other web application.
> Morrison
> Sent: Monday, July 30, 2007 3:53 PM
> User Account Control is wonderful for most users, however for most
> people doing development/support work it simply gets in the way.  I had
> already turned mine off long before I got around to loading Mapguide.
> Martin
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Angela
> Moore
> Sent: Monday, July 30, 2007 9:04 AM
> Subject: Re: [mapguide-users] Vista and Mapguide Server
> I've got MapGuide Server (1.2 RC2) running on Vista (32 bit).  I used
> the self extracting executable for windows and installed with
> Apache/PHP.  I ran into and fixed one  glitch while installing the
> samples to test the program on Vista.  Because MapGuide is installed in
> Program Files the all too annoying user permissions start to kick and
> scream in protest.  I had to allow all permissions for my administrative
> account within Program Files and then run the zip program in the Windows
> XP mode to open the sample files before I could get them installed.
> Eventually I just had to turn all of the User Account Controls off so
> that I could properly load data.  I know that Vista is trying to be
> /secure/ but their User Account Controls just give me headaches on a
> regular basis.  I would suggest that anyone having trouble with a Vista
> installation regardless of which web server or programing language you
> are using try turning off User Account Controls and giving it another
> swing.  Good luck!
> Angela Moore
> GIS Analyst
> Town of Franklin, NC
> amoore at franklinnc.com
> Ivan Milicevic wrote:
>> What's the key of sucesfully instalation? Share with us :)
>> Morrison
>> Sent: Friday, July 27, 2007 1:19 PM
>> I do.  64bit too.  Mapguide Studio will NOT work with the 64 bit
> though.
>> Martin
>> From: mapguide-users-bounces at lists.osgeo.org on behalf of Kenneth,
>> GEOGRAF A/S
>> Sent: Fri 7/27/2007 6:49 AM
>> You don't have to use the same machine.
>> In the webconfig.ini, you can specify IP and port mappings for the
>> server.
>> Does anyone have a working MapGuide Server on Vista?
>>> I need mapguide server on same machine where is my source code of
>> application because of developing.
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Bruno
>>> Scott
>>> Sent: Friday, July 27, 2007 12:21 PM
>>> To: mapguide-users at lists.osgeo.org
>>> I have just installed Mapguide Studio 2008 on my bran new Vista
>>> Ultimate And it works fine.
>>> Didn't try to install Mapguide Server
>>> I have a vmware virtual machine that runs windows 2003 with mapguide
>>> server on it.
>>> With this configuration, i got everything running, it's even faster
>>> having mapguide server on a virtual machine than on the same machine.
>>> Don't know why?
>>> Bruno Scott
>>> Ivan Milicevic-3 wrote:
>>>> Hello,
>>>> Just for information, Vista doesn't support Mapguide Server (any  of
>>>> version). It's problem with IIS 7.0.
>>>> Also, Mapguide Studio 2008 (2007 work's perfectly) doen't work on
>>>> this platform.
>>>> I hope so that this compatibility issue will be solved in futer
>>>> version od Mapguide Server and Studio.
>>>> Ivan Milicevic
>>>> voditelj Odjela za dokumentiranje
>>>> i projektiranje
>>>> SUPRA NET d.o.o.
>>>> Erlichova 2, 10000 Zagreb
>>>> CROATIA
>>>> Mobile: +385 (0)91 2352-320
>>>> Fax: +385 (0)1 6678-728
>>>> Email: ivan.milicevic at supranet.hr
> <mailto:ivan.milicevic at supranet.hr>
>>>> URL: www.supranet.hr <http://www.supranet.hr/>
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070730/77560e20/attachment.html
