[mapguide-users] export view to sdf
Zak James zak4ms at gmail.com
Tue Jul 31 15:39:10 EDT 2007
Todd,
If you want an complete file containing all the features in all the
visible layers I think you would need to use the API to create a
script that stepped through the layers in the map and copied features
within the current extents. You could then create a custom tool to
control the script from the ajax viewer.
zak
On 7/30/07, Todd Wells <twells at sveassoc.com> wrote:
> I apologize if this is a repeat question but through my research I have been
> unable to find the answer to this.... I am using mgos and and the ajax
> viewer... Is there a way to export the current view to an sdf file so I can
> import it back to autodesk map 08??? Plot to dwf works but unfortunately I
> am not able to do any coordinate transformation on insert dwf into autodesk
> map 08... thanks...Todd
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
