[mapguide-users] MapInfo problem
Stefan Dalakov s.dalakov at mapware.net
Tue Jul 31 23:21:27 EDT 2007
Hi Jackie,
I was out of office yesterday. You helped me a lot. In fact the
"mapviewerajax" virtual directory has been setup
as an application, but the "default document" was not enabled....
Thanks again.
Jackie Ng wrote:
> Hi Stefan,
> It sounds like the "mapviewerajax" virtual directory has not been setup /
> registered as an application.
> Are you using Apache or IIS?
> Does a url like this work for you?
> http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=<Path to a weblayout
> resource>
> OR
> http://localhost:8008/mapguide/mapviewerajax/?WEBLAYOUT=<Path to a weblayout
> resource>
> - Jackie
> Stefan Dalakov wrote:
>> I have to apologize, It is not connected to the provider. There is
>> something wrong with viewer. When I set the MG Studio to work with dwf
>> viewer
>>  it is OK. With the AJAX viewer I get this problem. I had Studio 2008
>> recently installed, so I guess there is the problem. Help will be
>> appreciated anyway....
>>> Hi all,
>>> I try to open Mapinfo files (TAB,DAT...) - rather old ones - version
>>> 3. I have installed the OGR provider. Test connection succeeds and in
>>> the preview pane of MG Studio I see data and geometry description.
>>> When I click on "View data" I see attributes listed - works perfect,
>>> but when I click on "view feature" and I expect to see features, I get
>>> this message :
>>>   Directory Listing Denied
>>> This Virtual Directory does not allow contents to be listed.
>>> What's wrong ? I am using MGOS 1.2RC2 on WinXP, I have no problem with
>>> other data sources
>>> Thank you in advance : Stefan Dalakov
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070801/60bc8e5b/attachment.html
