[mapguide-users] Generate KML with layers that are not based from WGS84 Datum
ori gudes ori at sinapistech.com
Mon Jul 30 12:50:13 EDT 2007
Hi  Friends
I want to generate KML based on Map (Layers) that are not in WGS84 datum,
can somebody tell what the necessary procedures  to make the KML work
properly in Google Earth in later stage ?
I have noticed that after using KML file based on *XY-M* (Arbitrary X-Y
Coordinates) Datum
It did not show in Google Earth, although it recognized the Layers Names.
Thanks in advance Ori
View this message in context: http://www.nabble.com/Generate--KML-with-layers-that-are-not-based-from-WGS84-Datum-tf4171200s16610.html#a11866780
