[mapguide-users] DWF Display Problem
Walt Welton-Lair walt.welton-lair at autodesk.com
Fri Jun 1 10:58:21 EDT 2007
I can't open the DWF file in my DWF Viewer - it says "There was a
problem displaying the file".  Is the posted file possibly invalid?  How
was it generated?  Looking at the first few bytes it claims it's a DWF
version 6 file, which means you should be able to open it using a Zip
utility.  But that also fails for me.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jon Rizzo
Sent: Friday, June 01, 2007 4:49 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] DWF Display Problem
The attached DWF does not display properly in the AJAX viewer.
Everything
looks okay except there is a long curved line at the bottom that does
not
show up in Autodesk's standalone DWF viewer.  I have other DWF files
exhibiting the same problem, but this file is much smaller.  I have not
tested this in the Beta as I do not have another machine available at
the
moment.
http://www.nabble.com/file/p10913970/display%2Bproblem.dwf
display+problem.dwf
View this message in context:
http://www.nabble.com/DWF-Display-Problem-tf3852634s16610.html#a10913970
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
