[mapguide-users] Building symbols
George McLean
gmclean at gorge.net
Fri Jun 1 17:28:36 EDT 2007
Thanks for the suggestion Brad. I did not find exactly what I was
looking for on http://commons.wikimedia.org.
I have been having some success creating fonts using FontCreator and
then importing the fonts into symbol libraries through Studio. This way
I do not have install the fonts when I deploy.
George
Brad Nesom wrote:
> Take a look at these svg symbols
> http://en.wikipedia.org/wiki/Primary_State_Highway_2_(Washington)
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of George McLean
> Sent: Friday, May 25, 2007 6:06 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Building symbols
> Thanks for the suggestion James. I will give this a try. I am guessing
> the ESRI symbols are proprietary and should not be used directly in MGOS
> even though they work well. Does anyone know if the ESRI symbols need to
> be licensed for use in MGOS?
> Thanks
> George McLean
> James H. Murphy wrote:
>> George,
>> This is what I have been doing for the past few months between support
> calls and demos. In Map3D I create Mtext using charmap and getting the fonts
> from the ESRI symbol library. Then I use the express tool text explode to
> turn those mtext objects into lines/plines. Then I run some of the map
> cleanup tools on those to get rid of the duplicate lines and so-on. Clean up
> what is left over and create blocks by-layer. It takes a while but that
> seems to work with the ESRI fonts to create symbols you can use in the FDO
> side of MAP 3D. Once I get "all" of them convert cataloged somehow, haven't
> gotten to that point yet they will be available for anyone that wants then.
>> Now whether they work in MGE or MGOS I don't know but for MAP3D they look
> good.
>> James Murphy
>> Applications Engineer
>> ALACAD
>> (205)444-3100
>> Visit us at www.alacad.com
>> Sent: Friday, May 25, 2007 3:46 PM
>> Subject: [mapguide-users] Building symbols
>> Hello,
>> I am looking for suggestions for creating nice looking symbols for MGOS
>> using Atuodesk Mapguide Studio. I have tried loading DWG files with
>> blocks that I would like to use with some success but I am having
>> trouble repeating this with other blocks and I am not sure why at this
>> point. Unfortunately when I did get some blocks to create symbols I
>> like, I did not save the load procedure so I can not remember what
>> parameters I set on the load procedure form! Are there any guidelines
>> for what settings to use in the load procedure for creating symbols from
>> autocad blocks?
>> I would also be interested in any suggestions on other methods to create
>> symbol libraries. I have tried to create fonts using FontCreater but
>> have not been successful yet most likely due to not understanding what I
>> am doing very well. I have tried to build a font library similar to the
>> ESRI libraries but I must be missing some key steps. When I build a font
>> and assign it to a position in the font table, I get the corresponding
>> ascii character instead of my symbol.
>> I have also tried importing bmp files into symbol libraries. but have
>> not had much luck here either. I can see the BMP in the symbol library
>> but when I style a point with it I can not see it in the map, layer
>> preview or when trying to set the reference point. Are there any
>> guidelines for this procedure like how big the file should be etc?
>> Sorry for all the rambling but as you can see I am a bit lost on symbol
>> creation.
>> Thanks,
>> George McLean
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> No virus found in this incoming message.
>> Checked by AVG Free Edition.
>> Version: 7.5.467 / Virus Database: 269.8.0/817 - Release Date: 5/24/2007
> 4:01 PM
>> No virus found in this outgoing message.
> 4:01 PM
