[mapguide-users] Upgrade from MGOS1.1 to MGOS1.2
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Jun 4 06:12:19 EDT 2007
Yes, you should be able to do that.
I've seen other complain about instabillity when upgrading.
I would recommend you uninstall first, then reinstall.
To be safe, you can make a backup of the packages and repository folder
in the installation directory before uninstalling.
Regards, Kenneth, GEOGRAF A/S
Andre Schoonbee wrote:
> Simple Question which was probably answered a few times
> I am Running MGOS1.1 n XP pro with Apache, php and also Autodesk MapGuide
> 2007.
> Without loosing work done, can I simply install the latest version without
> un-installing?
> Andre
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
