[mapguide-users] SHP Files Strike Again
Chris Gountanis cgountanis at mpower-tech.com
Mon Jun 4 16:38:24 EDT 2007
I guess my question is, where can you clear the pool cache when pooling is
enabled. Does a server restart handle it for you? I think it is causing
conflicts with SHP files when they are updated or replaced.
Dave,
I have moved to a single file per folder approach. Keep in mind the only
difference between managed and unmanaged connections is where the folder
located. Whether you have a single SHP or multiple files per folder that is
the problem.
Chris
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Monday, June 04, 2007 1:57 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] SHP Files Strike Again
Chris are you still trying to connect to a folder for SHP? It may be that
that is part of the issue. It might be worth falling back to a resource per
SHP file just like you have to do with SDF.
Regards,
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris Gountanis
Sent: Monday, June 04, 2007 12:14 PM
To: 'MapGuide Users Mail List'
Subject: [mapguide-users] SHP Files Strike Again
I was playing around with my unmanaged SHP files and now the server just
crashes on zoom. I created a separate unmanaged feature source to see  if it
was faster zoom wise and that seemed to cause the issue. I also edited the
layer to use new feature source with single SHP file and the preview in
Studio works fine. When bring the whole site up with AJAX viewer the issue
shows its face. Is there a reason why or a way to clear cache? I had turned
on SHP cache for pooling tests maybe that caused an issue? I am not sure
what the server is doing but it using 100% resources then crashes on zooms
now.
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070604/eb20c388/attachment.html
