[mapguide-users] Problem with legend - style
martijni
mis at gemeentehulst.nl
Tue Jun 5 03:09:21 EDT 2007
I'm glad to hear that :)
Well that's not exactly what I meant, but I still think you gave a little
bit of an awnser ;)
What I meant is that if the information gets updated or an extra row in the
Acces database gets added it will be shown in the viewer, instead that I
have to do the whole process again :)
So it's more that the layer stays the same while the information gets
updated..
Kenneth, GEOGRAF A/S wrote:
> I'm just happy to help :D
> The layer will stay as it is in the server.
> If you modify it with studio, it will get the extra legend stuff.
> If you don't want extra/changed theming there is no need to update it,
> even if the data changes.
> Not sure that was the question?
> Regards, GEOGRAF A/S
> martijni wrote:
>> Kenneth,
>> I feel pretty stupid right now... Instead of defining the Layerdefinition
>> I
>> always gave as resource FeatureSource :x
>> So I'm thanking you for the last post for what you've typed in. It's
>> working
>> now. My only question left is that when I remove the style types, that
>> shouldn't be seen in the legend and upload it like we did now, and the
>> information in the accesdatabase gets updated this automatic changes in
>> the
>> viewer. Or do you have to update the LayerDefinition each time?
>> Thanks for the help!
>>> I can get a similar exception if I type in
>>> Library://tank.MapDefinition
>>> as the resource id, if I type:
>>> Library://tank.LayerDefinition
>>> it all goes fine.
>>> Regards, Kenneth, GEOGRAF A/S
>>>> I've tried validating it. I validates fine for me.
>>>> I can also upload it using the test form. It shows in studio, but I
>>>> don't have the featuresource.
>>>> It would appear that the XSD files are broken in your install, or
>>>> something happened when you posted and I downloaded.
>>>> If possible, try uninstalling, remove the entire folder C:\Program
>>>> Files\MapGuideOpenSource, and reinstall.
>>>> Remember to backup any data you want to save. You might use the
>>>> package manager in the site admin for this purpose.
>>>> I was using MapGuide 1.2 Beta 2 for my testing.
>>>> martijni wrote:
>>>>> Kenneth,
>>>>> Thanks for your reaction.
>>>>> I uploaded the xml file for you. Take a look at it. I did a validation
>>>>> check
>>>>> and received no errors.
>>>>> As far as I can see it's using UTF-8. Maybe i'm wrong ofcourse.... :)
>>>>>> That probably means that the document you upload does not validate
>>>>>> according to the XSD schema.
>>>>>> You can find the XSD Schema's in the "Schema" folder where you
>>>>>> installed
>>>>>> MapGuide.
>>>>>> There are free xml validators on the web, that will give you more
>>>>>> detail
>>>>>> on what went wrong.
>>>>>> Be aware that there is a different schema for each resource type.
>>>>>> Also, you MUST use UTF-8 encoding (it will not give the above error,
>>>>>> but
>>>>>> won't display the map).
>>>>>> martijni wrote:
>>>>>>> James,
>>>>>>> I doubt that I misstyped the resource ID, because I tried different
>>>>>>> resource
>>>>>>> ID's to make sure it wasn't a typo. Each time I receive this
>>>>>>> exception:
>>>>>>> An exception occurred in the XML parser.
>>>>>>> An exception occurred in the XML parser. Exception occurred in
>>>>>>> method
>>>>>>> MgResourceContentManager.ValidateDocument at line 586 in file
>>>>>>> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\resource\ResourceContentManager.cpp
>>>>>>> Don't know if this gives you some more information...?
>>>>>>> James Card wrote:
>>>>>>>> On Fri, 01 Jun 2007 06:48:01 -0700, martijni <mis at gemeentehulst.nl>
>>>>>>>> wrote:
>>>>>>>>> I understand what you say, but do I have to reload the XML using
>>>>>>>>> the
>>>>>>>>> mapagent interface like this way:
>>>>>>>>> Resource --> SetResource --> Resource ID is location where the
>>>>>>>>> file
>>>>>>>>> will
>>>>>>>>> be placed
>>>>>>>>> Content is the location of the xml file
>>>>>>>>> Header is empty
>>>>>>>>> But when I did it this way I received an exception. Is this the
>>>>>>>>> way
>>>>>>>>> you
>>>>>>>>> should do it, or did you mean something else?
>>>>>>>> That is exactly the procedure we use here. Did you mistype the
>>>>>>>> Resource
>>>>>>>> ID? Is your XML file valid?
>>>>>>>> James Card
>>>>>>>> California CAD Solutions, Inc.
>>>>>>>> 209 578-5580
>>>>>>>> _______________________________________________
>>>>>>>> mapguide-users mailing list
>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>> http://www.nabble.com/file/p10952225/tanks.LayerDefinition.xml
View this message in context: http://www.nabble.com/Problem-with-legend---style-tf3847021s16610.html#a10964547
