[mapguide-users] Digitize functions cause jump on Mac
Jim O'Leary
joleary.public at gmail.com
Wed Jun 6 15:29:03 EDT 2007
This issue is similar to Ticket #5 in the Track system at
http://trac.osgeo.org/mapguide/ticket/5. However, the first proposed
solution causes the map to disappear in Safari. The second solution seems
difficult to implement as it means altering the internals of the map pane
javascript. Neither solution directly addresses the issue of the 2 3/8 jump
up in the browser on Sarari when you remove the floating Zoom zool. If no
one has a suggestion or objection, I'll file a ticket on this issue.
Jim O'Leary wrote:
> The DigitizePoint() and other Viewer digitizing functions cause the
> browser to jump upward on Firefox (PC and Mac) and Safari (Mac). When you
> remove the floating Zoom slider, the jump is 2 3/8 " on a 1024 x 768 Mac
> using Safari. I have confirmed this on various versions of of Mac, with
> the most recent Safari.
> Is this a known issue? If not I can submit a bug report.
View this message in context: http://www.nabble.com/Digitize-functions-cause-jump-on-Mac-tf3869534s16610.html#a10995608
