[mapguide-users] OGR / GEOS selection problem
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Jun 7 02:54:54 EDT 2007
Maciej previously reported problems with the OGR provider using PostGIS.
The problem is with the OGR provider.
Se the Trac ticket for details:
http://trac.osgeo.org/mapguide/ticket/172
I have posted some follow up on the issue, but in hope someone knows a
lot about GEOS, I'm also posting it here:
I have been examining the problem, using a custom build of the OGR
provider. It is true that without GEOS support in OGR, the Intersect
only does a BBOX check.
However, merely enabling GEOS will not work, as the viewer sends a
square that is orthogonal to the axes (like a BBOX). The GEOS library
will interpret this as another BBOX, and only perform the BBOX check
anyway.
When I change the polgyon sent from the viewer to a triangle, it takes
22 seconds to calculate the Intersects result with a polygon with 8000
linesegments. I have a 2+ GHz machine.
It seems that GEOS always builds a full intersection matrix, before
returning the result. This is obviously not optimal for a simple hit
test. Even with this knowledge, I still don't see how it can take 22
seconds to calculate 8000 * 3 intersections.
Can someone explain this, or how to fix it?
Regards, Kenneth, GEOGRAF A/S
