[mapguide-users] Getting all object Enveloppe
David Hequet
david.hequet at free.fr
Thu Jun 7 03:44:00 EDT 2007
and about "Select Envelope(geometry) from datasource"
I can do that with ExecuteSqlQuery ?
do you have a syntaxe sample? i think i have to check if the fdoprovider has
this "SpatialExtents" capability?
going through each object can be very slow on each map loading..
Kenneth, GEOGRAF A/S wrote:
> Yes, you have to run through each feature in the feature reader.
> Then on each feature, you have to use some of the obscure
> AgfReader/Bytereader stuff to get the actual object out of the geometry
> column.
> When you have the object, it has a GetEnvelope() method.
> Regards, Kenneth, GEOGRAF A/S
> David Hequet wrote:
>> Arg, i was so close of my goal
>> I think i have to take a look on your idea because of MGSelection seems
>> to
>> have a limit.
>> here is my code:
>> For i = 0 To aMgLayerCollection.GetCount() - 1
>> aLayer = aMgLayerCollection.GetItem(i)
>> aProvider = Me._getLayerSourceType(, aLayer)
>> If aProvider <> "Autodesk.Raster" And aProvider <> "DWF" Then
>> aLayerClassName = aLayer.GetFeatureClassName()
>> If aClassArray.IndexOf(aLayerClassName) = -1 Then
>> Me._log(aLayerClassName)
>> aLayerFeatureId = aLayer.GetFeatureSourceId()
>> aLayerResId = New MgResourceIdentifier(aLayerFeatureId)
>> aFeatureReader =
>> Me._featureService.SelectFeatures(aLayerResId,
>> aLayerClassName, aMGQueryOptions)
>> aMGSelection.AddFeatures(aLayer, aFeatureReader, 0)
>> aClassArray.Add(aLayerClassName)
>> End If
>> End If
>> Next i
>> aMgEnveloppe = aMGSelection.GetExtents(Me._featureService)
>> I got an error:
>> Une exception non classifiée s'est produite.Une exception non classifiée
>> s'est produite.
>> Une exception s'est produite dans la méthode
>> MgServerSelectFeatures.SelectFeatures à la ligne 217 dans le fichier
>> c:\build_tux_area\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
>> In english "non classified error"
>> When i use this method
>> it didn't happen every time:
>> on a map with ~30 features dispatched on 4 layers it's ok
>> on a map with ~1200 features on 2 layers it crash (if i try too much the
>> mgserver service crash).
>> i didn't see a getExtent method on the featurereader, i think i have to
>> check enveloppe for each feature in the reader?
>>> You don't have to use the selection part.
>>> You can extract the object directly from the feature reader.
>>> Once you have the object, you can also get the extent (aka bbox).
>>> If you then construct an envelope object, you can add the features
>>> envelope to original envelope.
>>> Something like:
>>> create a new MgFeatureQueryOptions with an empty filter
>>> create a new Envelope
>>> For Each Layer
>>> Use a featureReader with the MgFeatureQueryOptions
>>> Add the feature's envelope to the outer Envelope
>>> Get zoom extents from the Envelope
>>> Other than this, I don't think you can optimize it anymore, as you need
>>> to execute the query on each layer.
>>> I think there is a "Get Extents" on the feature source, but I can't find
>>> it. And I don't think it works on filtered datasources.
>>> Perhaps you can execute the query with some SQL optimizations like
>>> "Select Envelope(geometry) from datasource".
>>> Hope it helps.
>>> David Hequet wrote:
>>>> Hello,
>>>> I'm trying to make a fonction that can return me the enveloppe of the
>>>> entire
>>>> visible map (no way with original map extent).
>>>> Explain: I have a map "template" with a lot of layers, i have a
>>>> function
>>>> that change all the layer filter (basic filter, no spatial) to see
>>>> different
>>>> map based on that template. Doing that make the "zoom to original
>>>> extent"
>>>> useless, because data are not on the same area.
>>>> I wan't to set the new map extent in the MapDefinition.
>>>> My ask is about getting the new extent.
>>>> I thought to do it like that:
>>>> create a new MgSelection
>>>> For Each Layer
>>>> Add the selected feature to the MgSelection
>>>> Getting the MgSelection enveloppe
>>>> It will work, but i don't think it's very optimized with a lot of
>>>> Layer/Feature (and it will used at each map load, filter
>>>> modification..)
>>>> Did someone have a better way?
>>>> Thank you!
>>>> Ps: sorry for my poor english, ask i you want precision.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Getting-all-object-Enveloppe-tf3864317s16610.html#a11003408
