[mapguide-users] SDF File Size(Maximum)
Kenneth, GEOGRAF A/S
ks at geograf.dk
Mon Jun 11 05:06:22 EDT 2007
I have not tested this, only looked at it in theory. It looks as if the
provider can support at least 2GB, but there might be a limitation deep
inside Map3D.
Maybe some of the Autodesk people have tested this?
Regards, Kenneth, GEOGRAF A/S
Rahul skrev:
> Hi ,
> Thanks a lot for your detail reply and reference,so in theory we
> can say that it can support upto 2 TB depending upon the storage space
> and File System.
> I think leave about the TB and if we talk just about 2-3 GB ,do u
> think it is possible to work with a SDF File of 2-3 GB in Autodesk
> assuming that storage space is not an issue.(Similar to ESRI Personal
> GeoDatabase 4 GB Limit).
> Thks
> Max
> */"Kenneth, GEOGRAF A/S" <ks at geograf.dk>/* wrote:
> Hmm... a bit hasty there... the new info shows this:
> (10) Are there any known size limits to SQLite databases?
> A database is limited in size to 2 tibibytes (2^41 bytes).
> That is a theoretical limitation. In practice, you should try to
> keep your SQLite databases below 100 gigabytes to avoid
> performance problems. If you need to store 100 gigabytes or more
> in a database, consider using an enterprise database engine which
> is designed for that purpose.
> The theoretical limit on the number of rows in a table is
> 2^64-1, though obviously you will run into the file size
> limitation prior to reaching the row limit. A single row can hold
> up to 230 bytes of data in the current implementation. The
> underlying file format supports row sizes up to about 2^62 bytes.
> There are probably limits on the number of tables or indices
> or the number of columns in a table or index, but nobody is sure
> what those limits are. In practice, SQLite must read and parse the
> original SQL of all table and index declarations everytime a new
> database file is opened, so for the best performance of
> sqlite3_open() it is best to keep down the number of declared
> tables. Likewise, though there is no limit on the number of
> columns in a table, more than a few hundred seems extreme. Only
> the first 31 columns of a table are candidates for certain
> optimizations. You can put as many columns in an index as you like
> but indexes with more than 30 columns will not be used to optimize
> queries.
> The names of tables, indices, view, triggers, and columns can
> be as long as desired. However, the names of SQL functions (as
> created by the sqlite3_create_function() API) may not exceed 255
> characters in length.
> So, it should in fact support 2 titibytes, providing that the file
> system allows you to create files of that size (and you have
> enough storage space).
> Kenneth, GEOGRAF A/S skrev:
>> SDF is using the SQLite database for storage. The SQLite has the
>> following size constraints:
>> Internally, SQLite can handle databases up to 2^40 bytes (1
>> terabyte) in size. But the backend interface to POSIX and Win32
>> limits files to 2^31 (2 gigabytes).
>> SQLite arbitrarily limits the amount of data in one row to 1
>> megabyte. There is a single #define in the source code that can
>> be changed to raise this limit as high as 16 megabytes if desired.
>> There is a theoretical limit of about 2^32 (4 billion) rows
>> in a single table, but there is no way to test this limit without
>> exceeding the maximum file size, so it is not really an issue.
>> There is also a theoretical limit of about 2^32 tables and
>> indices, but again it is not really possible to reach this limit
>> due to the file size constraint.
>> The name and "CREATE TABLE" statement for a table must fit
>> entirely within a 1-megabyte row of the SQLITE_MASTER table.
>> Other than this, there are no constraints on the length of the
>> name of a table, or on the number of columns, etc. Indices are
>> similarly unconstrained.
>> So, if there are no bugs in the implementation, the size should
>> be limited to 2 GB. You can read more about the SQLite format on:
>> http://www.sqlite.org/
>> Rahul skrev:
>>> Hi All,
>>> Can anyone tell me that how much the maximum SDF File
>>> size(single) supported by Autodesk(ADSKServer,Map3D 2008).Any
>>> reference or detail link will be really helpfull for me.
>>> ESRI use to provide support for max. 4 GB personal geodatabase File.
>>> Thks
>>> Max
>>> It's here! Your new message!
>>> Get new email alerts
>>> <http://us.rd.yahoo.com/evt=49938/*http://tools.search.yahoo.com/toolbar/features/mail/>
>>> with the free Yahoo! Toolbar.
>>> _______________________________________________ mapguide-users mailing list mapguide-users at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Yahoo! oneSearch: Finally, mobile search that gives answers
> <http://us.rd.yahoo.com/evt=48252/*http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC>,
> not web links.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070611/6717fe2d/attachment.html
