[mapguide-users] Bad Performance using dwf Files
Maciej Skorczewski maciej.skorczewski at procad.pl
Tue Jun 12 04:54:56 EDT 2007
Hi Stephan!
Did you try Tile Base in Ajax Viewer?.
try use scale to show/hide some layer....
In my aplication i saw that if i show only shapes like (polygon, line)
whit 3-4 layer in Tile Base it is fast...but when yu put label (street
name etc) it generate bigger PNG so it is bit slower.
...still wainting for speed like in maps.google.com :)
...MG 1.3 ?
Stephan Hollaus pisze:
> I'm using dwf Files as drawing source, and the view is ok. But the
> Performance is very bad(~30sec after every Pan/Zoom)
> The dwf File is about 10MB. Is there a possibillity to generate an index for
> the dwf to make it faster? What else could i use?
> mfg
