[mapguide-users] RE: Desktop implementation of MapGuide
Kenneth, GEOGRAF A/S
ks at geograf.dk
Tue Jun 12 05:13:09 EDT 2007
I like webapps for things I do infrequently, such as look for street
adresses.
If I have to actually work with it, I prefer a desktop client.
I've tried both GMail and Google Calendar, and they are pretty and neat.
In the long run the Web apps have sluggish handling, periodic erros etc.
That is also true for GIS applications. If you want to present your map
to casual visitors, do use AJAX in a webapp.
If your job is working with GIS, use a desktop app.
So, things that cannot easily be done in web apps are:
Handling of files (due to security constraints)
Handling of clipboard data (due to security constraints)
A very fast, error free user interface (possible, but very hard, I have
yet to see one).
Handling network errors, server faults, etc.
Integration with existing applications, ea. word (again, security
constraints).
Regards, Kenneth, GEOGRAF A/S
Kneo skrev:
> Give me some examples of features that you can think of for a desktop
> application. Something which cannot be done (or maybe with a lot of
> difficulty) in a web browser.
> SER&TEC Antonio Lucas wrote:
>> Hi Kneo,
>> It's not true. In a desktop app you have the power of a desktop app and
>> .net
>> framework (.net controls, file system access etc) for example. The code in
>> your app runs directly, not through a web browser. If you plan to
>> implement
>> a hard client, a desktop app is the best way to do this.
>> Antonio Lucas
>> Project Manager
>> alucas at svl.es
>> www.svl.es
>> tel. 963·959·513
>> Fax 963·731·756
>> Avda. Ausias March 79 - 1
>> 46013 Valencia
>> Calle Canalejas 13 - 3
>> 03001 Alicante
>> Este mensaje puede contener información confidencial, privilegiada o datos
>> de carácter personal. Si usted no es el destinatario indicado en el mismo
>> o
>> el responsable de su entrega, le rogamos no copie o entregue este mensaje
>> a
>> nadie más. En dicho caso, por favor, destruya este mensaje y comunique a
>> Servitec Servicios Informáticos S.L. su recepción. Las opiniones,
>> conclusiones y demás informaciones incluidas en este mensaje que no estén
>> relacionadas con asuntos profesionales de Servitec Servicios Informáticos
>> S.L. se entenderán que nunca se han dado ni están respaldadas por Servitec
>> Servicios
>> -----Mensaje original-----
>> De: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] En nombre de Kneo
>> Enviado el: martes, 12 de junio de 2007 4:58
>> Para: mapguide-users at lists.osgeo.org
>> Asunto: Re: [mapguide-users] Desktop implementation of MapGuide
>> If this app has to run while being online, there is no distinct advantage,
>> is
>> there ? The killer app would allow you to connect to the server at the
>> start, fetch the map and then use it offline. Or better still, get the
>> layers from various servers and combine it in a single map on the desktop
>> application
>> Kenneth, GEOGRAF A/S wrote:
>>> Sort of...
>>> The current implementation of the API uses a local tcp connection to
>>> connect to the server.
>>> You may be able to fix this by supplying a custom "webconfig.ini", where
>>> you change the IP adress, but it might be a problem if you intend to use
>>> it outside of the LAN.
>>> You will not be able to use the MapGuide API in offline mode.
>>> Also, you will have to implement most of the functionality yourself
>>> (zoom, pan, etc), as that is written in AJAX.
>>> There exists functionality to get raster map, set selection etc, but it
>>> is still raster.
>>> You might be able to get away with embedding a web browser (like studio
>>> does), or simply use the DWF viewer as an ActiveX control.
>>> These will have to run online though.
>>> You can also copy all data from the server, using Fdo, and storing it
>>> locally in SDF files. That should give nice speed, but you will have to
>>> render the map yourself.
>>> I'm not sure how much info the standard DWF map contains, but you might
>>> convince the server to give you a full DWF copy of the map. If you have
>>> that, you should be able to use the DFW viewer in offline mode.
>>> Kneo skrev:
>>>> Would it be possible to have a desktop implementation of MapGuide
>>>> (offline
>>>> viewing) ? Basically, the desktop application created in VB.net will
>>>> connect
>>>> to a set of servers to fetch the map and then allow the user to browse
>>>> it
>>>> offline. Since the map is now copied to the local desktop, the speed and
>>>> flexibility will be immense.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/Desktop-implementation-of-MapGuide-tf3900680s16610.htm
>> l#a11072163
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070612/e99e1310/attachment.html
