AW: AW: [mapguide-users] Bad Performance using dwf Files
Stephan HOLLAUS
stephan.hollaus at hollaus.at
Tue Jun 12 06:49:58 EDT 2007
Ok. But in Shape are only the Polygons/Lines/Points which i could use for feature classes. But I'm searching for I solution for the Visualisation.(With many blocks, hatches, User defined Linetypes, offestted outlines...)
mfg Stephan Hollaus
Ingenieur Studio Hollaus
Tel.: +43 664 3387158
Fax.: +43 664 77 3387159
www: http://www.hollaus.at
Brandströmgasse 10
3100 St. Pölten
V55BCPWP
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Maciej Skorczewski
Gesendet: Dienstag, 12. Juni 2007 12:27
An: MapGuide Users Mail List
Betreff: Re: AW: [mapguide-users] Bad Performance using dwf Files
Hi
I use AutoDesk Map 3D 2007.
export as ->SHP (there are even export directly do MapGuide, but - in my
opinion - whit shp you can do much more.)
Maciek
Stephan HOLLAUS pisze:
> Where can I do this export from dwf to shp?
> Also my problem is, that I have to use dwf or a format like that because there are very complex visualizations.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
