AW: AW: [mapguide-users] Bad Performance using dwf Files
Stephan HOLLAUS
stephan.hollaus at hollaus.at
Tue Jun 12 11:50:33 EDT 2007
Thx. But Mapguide Studio Help says, that dwg Import has big Problems with Solid Hatches and Blocks. So I have to use dwf and there is no possibility to split the Layers in dwf Input.
mfg Stephan Hollaus
Ingenieur Studio Hollaus
Tel.: +43 664 3387158
Fax.: +43 664 77 3387159
www: http://www.hollaus.at
Brandströmgasse 10
3100 St. Pölten
V55BCPWP
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Andy Morsell
Gesendet: Dienstag, 12. Juni 2007 17:32
An: 'MapGuide Users Mail List'
Betreff: RE: AW: [mapguide-users] Bad Performance using dwf Files
I agree, to maintain the graphic fidelity of many things in a DWG file, such
as blocks, hatches, dimensioning and so on, DWF is the best format. The
slowness you are seeing is attributed to the DWF file having to be accessed
multiple times by multiple MapGuide layers and has been a performance issue
for quite some time, including the older MG6.5 DWF data provider. It
appears that caching for DWF is not efficiently done.
The single best thing you can do to increase performance is to split up your
DWF's by layer. This is easy to do if you use Autodesk Studio to import
(load procedure) your DWG file as MapGuide drawing source data and choose to
have it create one drawing source per layer.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Stephan HOLLAUS
Sent: Tuesday, June 12, 2007 3:50 AM
To: MapGuide Users Mail List
Subject: AW: AW: [mapguide-users] Bad Performance using dwf Files
Ok. But in Shape are only the Polygons/Lines/Points which i could use for
feature classes. But I'm searching for I solution for the
Visualisation.(With many blocks, hatches, User defined Linetypes, offestted
outlines...)
mfg Stephan Hollaus
Brandströmgasse 10
3100 St. Pölten
V55BCPWP
[mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Maciej
Skorczewski
Gesendet: Dienstag, 12. Juni 2007 12:27
An: MapGuide Users Mail List
Betreff: Re: AW: [mapguide-users] Bad Performance using dwf Files
Hi
I use AutoDesk Map 3D 2007.
export as ->SHP (there are even export directly do MapGuide, but - in my
opinion - whit shp you can do much more.)
Maciek
Stephan HOLLAUS pisze:
> Where can I do this export from dwf to shp?
> Also my problem is, that I have to use dwf or a format like that because
there are very complex visualizations.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
