SPAM-LOW: [mapguide-users] RE: MapGuide Service Stops after sometime.
Andy Morsell amorsell at spatialgis.com
Wed Jun 13 01:11:32 EDT 2007
It's a setting in the Windows service itself.  Look in the Recovery tab of
the MapGuide Server service properties and you will see the options.
Unfortunately, this doesn't always help and I've see MapGuide lock up many
times in such a way that the service isn't aware that it's gone sideways.
In these cases, manually killing the process is usually required.
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jim O'Leary
Sent: Tuesday, June 12, 2007 7:07 PM
To: mapguide-users at lists.osgeo.org
Subject: SPAM-LOW: [mapguide-users] RE: MapGuide Service Stops after
sometime.
How do you set the MapGuide server to auto restart? I don't see any such
setting in the mapadmin.
Thanks.
Willem Schwarte wrote:
> We also have this problem, you can try to set the service to auto
> restart.
> Willem
> -----Oorspronkelijk bericht-----
> Van: Sajith S [mailto:sajith at kalkitech.com]
> Verzonden: donderdag 20 juli 2006 6:19
> Aan: MGOS Users
> Onderwerp: [mapguide-users] MapGuide Service Stops after sometime.
> Hi,
> I am new to MapGuide Open Source Server.
> I setup the mapGuide Server in a windows 2000 Prof. environment with
> Ajax viewer.
> The sample provided along with the mapguide ,Sheboygan is working fine.
> Now i am creating my own application using Autodesk Mapguide Studio
> 2007 Preview
> MapGuide Server version is 1.0.0.16407
> Now i am facing some problems, i created the my own application which
> uses SHP files.
> Now the Ajax Viewer displays the Map etc. But after sometime after
> 10-15 minutes Mapguide Server Service pop-up some error which is
> getting logged in the event logger. After this error my application
> stops working if i stop and start the service then it starts again.
> Error shown in the System log of event viewer is given below.
> Application popup: MgServer.exe - Application Error : The instruction
> at "0x00fcfd2e" referenced memory at "0x00000000". The memory could
> not be "read".
> thanks
> Sajith S
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context:
http://www.nabble.com/MapGuide-Service-Stops-after-sometime.-tf1970237s16610
.html#a11091386
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
