Same error. Can you compile the dll with select/add/update support on PostGis? I need support it in Map 2008. -- View this message in context: http://www.nabble.com/OGR---GEOS-selection-problem-tf3882162s16610.html#a11096005 Sent from the MapGuide Users mailing list archive at Nabble.com.
