[mapguide-users] RE: OGR Provider
larry white larz at neomatix.ca
Thu Jun 14 08:57:15 EDT 2007
i've compiled and tested ogr provider - for postgis and oracle spatial
support - in linux using gdal 1.4.0.
as far as i can tell there is no insert/update/delete capabilities.
i have also tested ogr provider and fdopostgis in winXP and those
capabilities do not seem to be present there, either.
Mateusz, is this a correct evaluation of fdopostgis?
also, will fdopostgis be made available for linux?
i took a look at the source code and it seems to be windows-specific
(mind you, my dev strengths are not c/c++).
perhaps i've missed something somewhere along the line - is there an fdo
provider that has more than read-only capabilities for postgis?
can someone confirm that this is actually the case?
are there plans to add insert/update/delete capabilities to the postgis
-capable providers?
i'd love to help out (or be a guinea pig), in any manner i can, as this
would be incredibly useful for me and, from the sounds of it, for others
as well.
-- larry
Kenneth, GEOGRAF A/S wrote:
> My experiments with OGR, shows that PostGIS does accept that you set the
> READOLY to "false".
> It is required to be false, if there are no spatial tables in the database.
> I haven't tried to actually create or update anything though.
> Also, I tried this with GDAL 1.4.1, and Traian made the provider with
> 1.4.0 (afaik).
> Regards, Kenneth, GEOGRAF A/S
larry white
Senior Systems Analyst
Neomatix Corporation
email: larz at neomatix.ca
url: www.neomatix.ca
