[mapguide-users] King.Oracle 0.7.0 - important improvements in
stability
Haris Kurtagic
haris at sl-king.com
Fri Jun 15 09:39:32 EDT 2007
new version of King.Oracle 0.7.0 provider is available at
www.sl-king.com/fdooracle
It is important release regarding stability of provider.
* Solved issue with multithreading support
Provider stopped responding in some cases like hitting refresh
map while map is already refreshing.
* Support for concurrent multi-user Insert/Update/Delete
In case of concurrent edits trough provider
* Support for selecting points from "KingFdoClass"
Added support for selecting points if points are created from
x,y,z numeric columns
* Build with Oracle 10.2.0.3
Build with new version of Oracle client files. Should work with
older client (10.2.0.1 ) also.
Haris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070615/441cd8b4/attachment.html
