[mapguide-users] MapGuide Open Source 1.2.0 Release Candidate 2
Tom Fukushima tom.fukushima at autodesk.com
Tue Jun 19 12:11:36 EDT 2007
Hi Andy,
Bruce told me that:
Some of the settings have changed so replacing the newly installed
serverconfig.ini file with the old one is not recommended. What should
be done is use the new file and migrate your settings over.
Tom
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Monday, June 18, 2007 10:36 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] MapGuide Open Source 1.2.0 Release
Candidate 2
Tom,
When upgrading from beta, RC's, to final releases, etc. are we generally
safe retaining and re-using the serverconfig.ini?  As more and more
configuration options are stored in that file, including the repository
folder paths, unmanaged aliases, pooling setttings, etc. it would be
easiest to save this file and then overwrite the new one rather than
re-merging the changes.
Thanks,
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Tom
Fukushima
Sent: Monday, June 18, 2007 7:29 AM
To: mapguide-users at lists.osgeo.org; mapguide-announce at lists.osgeo.org
Subject: [mapguide-users] MapGuide Open Source 1.2.0 Release Candidate 2
(Sent to MapGuide Announce and MapGuide Users)
This is to announce that the MapGuide Open Source project team has made
MapGuide Open Source 1.2.0 Release Candidate 2 available.
The following notable ticket fixes were done between RC1 and RC2:
#125 - AJAX Viewer: Selecting result of custom search zooms to wrong
location - update
#142 - Part 2 - Fix validation code that wasn't using localized decimal
and thousand separators
#184 - Update schema report pages to handle restricted character
escaping used by FDO in DescribeSchemaAsXml
#195: GetFeature GET request returns no features if MAXFEATURES is not
set
#196 - Some polyline labels are inverted
#198 - 1.2.0 RC1 Custom Search causes error in task pane
#200 - MapAgent Test Page Failures on .net
#201 Repository Admin scripts fail when using PHP4
#202 - Daily log archiving failing to archive on a daily basis
#204 Buffer on RDBMS polygon layers fail with coordinate system
conversion error
#206 - WMS: getfeatureinfo error on 1.2.0 RC1
#207 - mapadmin/constants.php file name is different in Win and Linux
Release notes: http://trac.osgeo.org/mapguide/wiki/Release/1.2/Notes
Documentation: http://mapguide.osgeo.org/1.2/documentation.html
Downloads: http://mapguide.osgeo.org/downloads.html
Summary of the new features as well as updated components in this
release (also listed at http://trac.osgeo.org/mapguide/roadmap):
Cartographic Enhancements - Phase I
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc14
    * Ability to define simple and composite symbols as XML resources
    * Ability to use new symbols for Points and Labeling Linear Features
(e.g. Highway Shields)
Pragmatic Load Balancing
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc3
Feature Join Enhancements
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc5
Support coordinate system overrides on feature sources
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc6
Support for Unmanaged Data Sources
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc2
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc12
Web interface for previewing a feature source
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc8
Extrusion support for KML
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc16
Line widths specified in map space
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc17
Tile handling enhancements
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc11
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc13
API enhancements
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc9
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc15
Significant performance enhancements in
    * Rendering
    * Tile Serving
    * Joins
Component Updates
    * FDO 3.2.2
    * GDAL 1.4.0
    * PROJ.4 4.5.0
    * PHP 5.2.1
Please enter any defects you might find using the instructions found at
http://trac.osgeo.org/mapguide/wiki/SubmitTicket.
Special thanks to some of our new code contributors for this release:
Jose Manuel Cerrejon Gonzalez - for the loading status indicator, mouse
wheel support and scale status bar work.
Atanas Rusev - submitting fixes for compilation issues on FC 6.
Chris Goutanis - submitting fixes for compilation issues on Gentoo.
Rex Szeto - for submitting the code for
Helio Chissini de Castro - for creating Mandriva binaries.
There are probably others that I have missed. If you know of anyone I
have missed or if I have missed you, please send me an email and I'll
make sure to update the next notice.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070619/0fcbadf0/attachment.html
