[mapguide-users] RE: How to enable markup using Design review
Jackie Ng
jackie.ng at aecsystems.com.au
Tue Jun 19 19:12:58 EDT 2007
What walt meant, was to use the MapGuide RenderingService APIs to create your
EPlot DWFs.
- Jackie
christophe_geomap wrote:
> I try to save a map with the IAdDwfViewer::SaveAs method, but it doesn't
> work !
> With the IAdDwfViewer::ExecuteCommandEx("SAVEAS",0), i can save the DWF
> but i don't know how to catch the new filename.
> Do you have any idea ?
> Christophe
> Walt Welton-Lair wrote:
>> The markup functionality in Design Review is not used by MapGuide. When
>> using ADR or DWF Viewer to view MapGuide maps, you're using the EMap
>> viewer functionality. EMap does not support markups.
>> MapGuide does let you save your current view of a map as an EPlot DWF.
>> You could then open that EPlot in ADR and add markups.
>> Walt
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
>> Sent: Thursday, January 25, 2007 10:21 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] How to enable markup using Design review
>> I have installed the design review software instead of the dwf viewer.
>> When using mapguide with dwf i don't have access to the markup tools.
>> If i open the about command, it tells me that i'm really using the
>> "design
>> review"
>> So my question is "How to enable markup using Design review in mapguide"
>> View this message in context:
>> http://www.nabble.com/How-to-enable-markup-using-Design-review-tf3097065
>> s16610.html#a8598618
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/How-to-enable-markup-using-Design-review-tf3097065s16610.html#a11204639
