[mapguide-users] Save user drawn polygon to an existing layer
Brad Nesom kidsmake6 at msn.com
Tue Jun 19 22:19:26 EDT 2007
Is it an RDBMS? Do you need a commit?
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Farah
Sent: Tuesday, June 19, 2007 8:41 AM
To: 'MapGuide Users Mail List'
Subject: [mapguide-users] Save user drawn polygon to an existing layer
Hi Folks,
I am trying to draw a polygon on the map and then save it as a feature, back
to a layer of the map ,which exists in the library. I am able to draw the
polygon on map,  get its coordinates, create an MgPolygon type , create the
corresponding properties and Insert the polygon in the layer. I do a client
side refresh after the layer is updated. However, the new polygon does not
apear on the map. I am attaching my code (in jsp) which does the above. Is
there anything extra that I need to do so as to show the feature on map?
Thanks and Regards
Farah Iqbal
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070619/8d58602a/attachment.html
