[mapguide-users] Producing High Resolution images using
Traian Stanev traian.stanev at autodesk.com
Thu Jun 21 22:43:52 EDT 2007
I don't remember, I may have somehow hardcoded the dpi value, since I was running from source.
If it really is not possible to set the dpi using the API, this is one thing that could be entered as an enhancement artifact, since I don't see it being hard to fix -- dpi is already supported in the actual rendering code.
Traian
	-----Original Message-----
	From: mapguide-users-bounces at lists.osgeo.org on behalf of Simon Hope
	Sent: Thu 6/21/2007 10:14 PM
	To: mapguide-users at lists.osgeo.org
	Cc:
	Subject: [mapguide-users] Producing High Resolution images using
	Traian,
	Thanks for the info – very useful.
	From reading the web API documentation the use of both width and height is clear (via the MgRenderingService class) – however defining dpi as a property of the image is not – I assume this is a property of the map itself exposed via GetDisplayDpi?
	If this is the case how is dpi on the map set?
	Cheers
	Simon
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070621/f76a8ad0/attachment.html
