[mapguide-users] Default action on map
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri Jun 22 10:41:52 EDT 2007
If you use the AJAX viewer you can modify this behaviour in the file
ajaxmappane.templ.
You might get away with a simple javascript timer, that changes the
current tool.
That would work with both dwf and ajax viewer, and not require you to
modify files.
Regards, Kenneth, GEOGRAF A/S
Krunoslav skrev:
> Krunoslav wrote:
>> Hi all.
>> As you know, the default action when the map loads is "Select". Is it
>> possible to change this? I would like "Pan" to be default action.
> Really no one knows or it's not possible ?
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070622/0d807989/attachment.html
