[mapguide-users] Build Problem
Kenneth, GEOGRAF A/S ks at geograf.dk
Sun Jun 24 06:51:56 EDT 2007
You must build the "Oem" solution before attempting to build the "Server".
The ACEd.dll comes from the Oem package ACE.
The "d" indicates that you want to build the "Server" in debug mode.
You must have the "Oem" built in debug mode as well.
You will also need to download and build FDO with SDF and SHP in debug mode.
Regards, Kenneth, GEOGRAF A/S
OGITerry skrev:
> I am new to MapGuide and I am trying to build RC2 in Visual Studio 2005.
> After getting numerous errors, one of the causes is a missing ACEd.lib file.
> So I checked the folder and the RMCast folder is full of 0 byte files.
> Thinking that I got a corrupted tar file I re-downloaded and found the same
> (also the same 0 byte files for RC1, and 1.1). I also tried all three
> versions on Suse 10, just in case winrar was corrupting the files as it
> extracted them. I didn't find a version with good files till version 1.0.2
> which seem to be of an earlier version of ACE. I have checked the ACE
> website and haven't found the needed ACEd.lib file.
> Am I missing something?
