[mapguide-users] MAPNAME & Map.Open
Mark Pendergraft markp at Meadgilman.com
Wed Jun 27 22:56:25 EDT 2007
I'm hoping that someone can help me with a few questions:
1)  How are people passing the MAPNAME variable to their application
pages?   I understand that you can use the javascript function
parent.parent.mapframe.getmapname, however, I am unsure how to retain
the value from this.  How do I transfer this variable to my asp.net
page.
2)  I am unable to open a Map at all.  Every app I have made so far
creates a map.  My code thus far:
<!-- #Include File="../UtilityFunctions.aspx" -->
<script runat="server">
    Private webLayout As String =
"Library://Kroll/Layout/MGAJobMapLayout.WebLayout"
    Private MapDef As String = "Library://Kroll/Map/MGA.MapDefinition"
    Private defaultUser As String = "Anonymous"
    Private defaultPassword As String = ""
    Private sessionId As String = ""
</script>
    Try
        InitializeWebTier()
        Dim SessionId As String = GetRequestParameters("SESSION")
        Dim UserInfo As New MgUserInformation(defaultUser,
defaultPassword)
        Dim site As New MgSite()
        site.Open(UserInfo)
        'for testing purposes only
        If SessionId = "" Then site.CreateSession()
        Dim ResourceService As OSGeo.MapGuide.MgResourceService
        Dim siteconnection As New MgSiteConnection
        siteconnection.Open(UserInfo)
        ResourceService =
siteconnection.CreateService(MgServiceType.ResourceService)
        Dim MapDefId As New MgResourceIdentifier(MapDef)
        Dim MapName As String = MapDefId.Name
        Dim Map As New MgMap(siteconnection)
        Map.Open(ResourceService, MapName)
        Dim srs As String = Map.GetMapSRS
        Response.Write("Map <strong>" + Map.GetName + "</strong> uses
this reference system: </br>" + srs + "</br></br></br>")
        Dim MapLayers As MgLayerCollection
        MapLayers = Map.GetLayers
        Dim Layer As MgLayer
        Response.Write("<strong>Map Layers</strong></br>")
        For Each Layer In MapLayers
            Response.Write(Layer.Name + "</br>")
        Next
    Catch ex As Exception
        Response.Write(ex.Message)
        Response.Write(ex.StackTrace)
    End Try
This code errors out at Map.Open everytime
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070627/d57cc990/attachment.html
