[mapguide-users] Custom layouts...
anakando anakando at yahoo.com
Wed Jun 27 23:36:48 EDT 2007
hi guys..
see attachment. how can i create a link to toggle selected layers from
button as show below?? so,users wiill have 2 option to toggle a layer,
either from lagend panel,or from click on a button that i create using
firework.. http://www.nabble.com/file/p11336461/gisweb.jpg ??
Kori Maleski-3 wrote:
> Hi All,
> I am trying to embed a legend in a separate web page.  Does anyone still
> have some of the examples that were floating around last year?
> Cheers,
>   _____
>  <http://www.websoftdev.com/>
> Kori Maleski
> Senior Application Developer
> WEBSOFT DEVELOPERS, INC.
> P: (530) 759-8754 ext 114
> F: (530) 759-0923
> kori.maleski at websoftdev.com
>   _____
> RE: Custom layouts...  <javascript:%20void%20Nabble.setFlag();> Click to
> flag this post
> by Alain Lebatard
> <http://www.nabble.com/user/UserProfile.jtp?user=321469>
> Mar 22, 2006; 09:20am :: Rate this Message:
> <http://www.nabble.com/forum/ViewPost.jtp?post=3536772&framed=y&skin=16610##
>> (use ratings to moderate[? <http://www.nabble.com/help/Answer.jtp?id=16>
> Reply <http://www.nabble.com/forum/Reply.jtp?post=3536772>  | Reply to
> Author <http://www.nabble.com/user/SendEmail.jtp?type=pm&post=3536772>  |
> Show Only this Message
> <http://www.nabble.com/RE%3A-Custom-layouts...-p3536772s16610.html>  |
> Link
> to this Message
> <http://www.nabble.com/Custom-layouts...-tf1319084s16610.html#a3536772>
> Jason,
> I attached a couple HTML pages that show you a possible approach in
> displaying the legend control in another place In this example the legend
> control runs in an IFrame at the right of the viewer (see screen snapshot
> below
> This approach requires no code change in the template files. The main
> issue
> is that the legend control and the viewer call each other, the viewer to
> set
> the scale as the map is navigated, or to refresh the control among other
> things, and the legend control to change the visibility of layers and
> groups. When the frame hosting the control changes, the way the control
> and
> the viewer reference each other in the code needs to change as well. The
> reference to the AJAX viewer in the legend control code was hardcoded. I
> changed this and I will submit the change to the mapguide trunk shortly.
> The
> reference to the legend control from the AJAX viewer is hold by a variable
> so all needs to be done is changing the content of this variable to point
> to
> the new control.
> The sample script 'legendpane.html' shows you how to wait for the map to
> be
> fully initialed, create a new legend control (not the new parameter
> MAPFRAME
> to the LegendCtrl.php request), and when this control is fully
> initialized,
> sets a reference to it in the AJAX viewer. From that point on the AJAX
> viewer will interact with the new control.
> The drawback of this approach is that the initial legend control is still
> there, only not visible. But it's not a big deal, the control is inactive
> after you attached the new instance to the AJAX viewer. The advantage of
> this approach, which to my opinion far outweighs the drawback, is that it
> requires no change in the existing surround.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Custom-layouts...-tf3183168s16610.html#a11336461
