[mapguide-users] build_oem.sh on Ubuntu 6.10
Ray Holtz ray at rayholtz.com
Thu Jun 28 23:31:33 EDT 2007
Hi I read the archives and in March someone was having troubles getting
the build_oem.sh script to finish installing.  I never read a complete
answer for that.  And I am having troubles in about the same spot.  Here
is the end of the output of running ./build_oem.sh as root:
dwfcore: Initialization...........................
/usr/local/maptemp/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore
/usr/local/maptemp/mapguide-1.1.0/Oem /usr/local/maptemp/mapguide-1.1.0
aclocal: configure.in: 11: macro `AM_PROG_LIBTOOL' not found in library
autoreconf: aclocal failed with exit status: 1
dwfcore: Configure /Build...........................
/usr/local/maptemp/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src/dwfcore
sh: ./configure: No such file or directory
make: *** No targets specified and no makefile found.  Stop.
DWFCORE 1.0: Error build failed (0).................
root at MapGuide:/usr/local/maptemp/mapguide-1.1.0#
Can anyone point me in the direction I need to fix this?
Thanks!
Ray
