[mapguide-users] Clear Selection
Chris Claydon chris.claydon at autodesk.com
Fri Jun 29 17:38:02 EDT 2007
This issue is described in trac ticket 37...
http://trac.osgeo.org/mapguide/ticket/37
It was fixed about three months ago. Which version of MapGuide are you
seeing this with?
Chris.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of RichBauer
Sent: June 29, 2007 2:18 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Clear Selection
Has anyone experienced the problem of when say a parcel (polygon) is
selected
and the properties display just fine and then you use the "Clear
Selection"
command from the right-click menu, the highlighting clears, but the
properties window does not clear?  If so, is there a way to fix it?  It
is
not a big deal, just for cleanliness.  Thanks.
Rich
View this message in context:
http://www.nabble.com/Clear-Selection-tf4001770s16610.html#a11366536
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
