[mapguide-users] RE: RE: RE: Guestion about speedup mapguide,
diferent domainname to mapagent.fcgi.
Kencana
bluesky_dyx at hotmail.com
Thu Mar 1 01:19:45 EST 2007
Is filtering also make the things become slower like you say for the
tooltip?
Regards,
Kencana
Jonathon-12 wrote:
> Is there only the tooltip column in the shape file? Also, can you have
> different layers for different scales that don't use tootips for the
> initial
> map.
> Be limiting tooltips/working with scales, we were able to take initial
> load
> times from about 30 seconds to 5-8 seconds. More in line with MG 6.5 with
> ActiveX.
> J
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kencana
> Sent: Wednesday, February 28, 2007 8:42 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RE: RE: Guestion about speedup mapguide,
> diferent
> Hi Jonathon,
> thanks for the feedback. I am using sdf file for the source. well it is
> actually from shp file and mapguide studio convert it to sdf file. as for
> the tooltip, it is one of the compulsory thing so i guess i need to use
> it.
> Thanks
> Regards,
> Kencana
> Jonathon-12 wrote:
>> Hi Kencana,
>> I had a look at your site and agree that the performance is a lacking.
>> I also don't know what your source is (SHP etc) but I have definitely
>> found that the attributes attached make a huge difference (I started
>> stripping out any data-it goes into a SQL Server database that I index
>> as much as I can- in my shape dbfs that I don't use for tooltips and
>> it helps a lot). I also use tooltips and labels as sparingly as
>> possible (if you can, allow the user to select the item to get
>> attribute info). It seems that there is a lot of information showing
>> in the initial map view...can you remove some of the layers or thin
>> the data, this helps.
>> Hope that some of this might help...
>> Cheers,
>> Jonathon
>> Sent: Wednesday, February 28, 2007 6:44 PM
>> Subject: [mapguide-users] RE: Guestion about speedup mapguide,
>> Hi,
>> the following is the url of my map. you can see that the map loading
>> is very slow.
>> by the way i am not using map tiled as because the map tiled initial
>> view took longer time than the other one.
>> any idea of improving it?
>> http://202.172.177.8/mapguide/mapviewerajax/?WEBLAYOUT=Library://Web/Y
>> P%20SG
>> %20Trial.WebLayout&LOCALE=en
>> Thank you very much
>> Regards,
>> Kencana
>> JasonBirch wrote:
>>> Paul wrote:
>>>> m1.google.com
>>>> m2.google.com
>>>> m3.google.com
>>>> and that each of these resolves to the same IP.
>>> And that IP address is probably a load balancer... I'm pretty sure
>>> that this single IP thing is not part of the performance measures.
>>> Traian wrote:
>>>> But then I decided that this can be worked around by using a file
>>>> system mount from the web server to the server where the tiles are.
>>>> I've seen a similar thing done on Linux/Apache, not sure if Windows
>>>> could handle such a setup.
>>> I've done this with IIS (CIFS share) and, while I can confirm that it
>>> works, it's a pain to set up and the performance is very poor
>>> compared to local filesystem access.
>>> While this might be a good solution for some situations (like, where
>>> the tile servers are behind a firewall?), I think that it would be
>>> best to also have the option of being able to set up a local
>>> webserver on the tile servers to serve the tiles directly to the
>>> clients rather than having to do everything through the web tier server.
>>> Jason
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/Guestion-about-speedup-mapguide%2C-diferent-doma
>> inname
>> -to-mapagent.fcgi.-tf3307731s16610.html#a9242845
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> http://www.nabble.com/Guestion-about-speedup-mapguide%2C-diferent-domainname
> -to-mapagent.fcgi.-tf3307731s16610.html#a9243904
View this message in context: http://www.nabble.com/Guestion-about-speedup-mapguide%2C-diferent-domainname-to-mapagent.fcgi.-tf3307731s16610.html#a9244527
