[mapguide-users] [Mapguide_users] Studio Specify Frame outsideof
Viewer Frames?
Chris Gountanis
cgountanis at mpower-tech.com
Thu Mar 1 09:34:35 EST 2007
Yes, the bottons invoke URL to a custom ASPX page in the hidden
"scriptFrame". That custom page set some ASPX session variables (like the
selection xml) and used JavaScript to frame.location("") my new page in my
outer frame. Gives the illusion of something like a Selected Parcels report
running in some outer frame without touching the task area. It's a bit of a
work around but it works nicely.
There are some major limitations to forms the target="" cannot be complex.
Chris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Gunter Becker
Sent: Thursday, March 01, 2007 5:22 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] [Mapguide_users] Studio Specify Frame
outsideof Viewer Frames?
Hi Chris,
i have exactly the same problem. Have you got any solution right now?
Gunter
Chris Gountanis wrote:
> OK. I want to run the tasks in a footer frame I created using the studios
> wizards. There is a header frame, map frame containing "the mg viewer" and
> the a footer frame. I can do URL invokes and have my own custom page hit
> the
> footer frame just fine from the right task area. Tested out fine. I cannot
> get the wizard created tasks to open anyway but taskframe. For example: if
> I
> open a custom page in the taskArea then
> top.footermainpage.navigate("http://www.google.com"); works. I can't for
> the
> life of me get the Studio specify frame to do the same when activating. I
> click the task be it on toolbar or task list and it opens in new window. I
> have tried many combinations. Image included. Anyone have any examples or
> tips on this?
> Chris
> Mapguide_users mailing list
> Mapguide_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide_users
View this message in context:
http://www.nabble.com/-Mapguide_users--Studio-Specify-Frame-outside-of-Viewe
r-Frames--tf2949515s16610.html#a9247817
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
