[mapguide-users] RE: RE: Guestion about speedup mapguide, diferent domainname to mapagent.fcgi.
Trevor Wekel trevor.wekel at autodesk.com
Thu Mar 1 12:35:08 EST 2007
Hi Kencana,
Have your turned on the various caches for FeatureService in
serverconfig.ini?  Here's a set of parameters I have used successfully
on a map with 90 SDF layers.
[FeatureServiceProperties]
CacheSize                          = 600
CacheTimeLimit                     = 86400
CacheTimerInterval                 = 3600
DataCacheSize                      = 100
DataConnectionPoolEnabled          = 1
DataConnectionPoolExcludedProviders= OSGeo.SHP
DataConnectionPoolSize             = 200
DataConnectionTimeout              = 600
DataConnectionTimerInterval        = 60
Thanks,
Trevor
-----Original Message-----
Sent: Thursday, March 01, 2007 7:51 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] RE: RE: Guestion about speedup
mapguide,diferent domainname to mapagent.fcgi.
That's a lot of layers. As I said, consider making the layers not
visible in the legend because it seems like the viewer is requesting
legend bitmaps for each layer/theme even though there is no visible
legend.
Are you using filters on the layers, and if yes, how complex are they?
The map is really slow to repaint even when there are very few features
visible so it must be the queries to FDO that are taking very long
(which includes whatever MapGuide does per layer in order to set up the
FDO select command).
How many of the layers are selectable or have a tooltip?
Traian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kencana
Sent: Wednesday, February 28, 2007 11:36 PM
Subject: [mapguide-users] RE: RE: Guestion about speedup mapguide,
for your information that there are 72 layers used for the map. and I
didn't use any feature join at all.
Thanks
Regards,
Kencana
Traian Stanev wrote:
> One thing I notice is that whenever I zoom in and the scale range
changes,
> the viewer makes many http requests to fetch layer legend images, even
> though there doesn't seem to be a layer legend in your map. So you
should
> look into that.
> Viewing operations like pan also seem very slow. Hard to tell why
without
> knowing where the features are coming from (SHP, SDF, joins?). Also,
is
> the coordinate system of the layers the same as that of the map?
> Traian
> 	From: mapguide-users-bounces at lists.osgeo.org on behalf of
Kencana
> 	Sent: Wed 2/28/2007 9:44 PM
> 	Cc:
> 	Subject: [mapguide-users] RE: Guestion about speedup mapguide,
diferent
> 	Hi,
> 	the following is the url of my map. you can see that the map
loading is
> very
> 	slow.
> 	by the way i am not using map tiled as because the map tiled
initial view
> 	took
> 	longer time than the other one.
> 	any idea of improving it?
http://202.172.177.8/mapguide/mapviewerajax/?WEBLAYOUT=Library://Web/YP%
20SG%20Trial.WebLayout&LOCALE=en
> 	Thank you very much
> 	Regards,
> 	Kencana
> 	JasonBirch wrote:
> 	> Paul wrote:
> 	>> m1.google.com
> 	>> m2.google.com
> 	>> m3.google.com
> 	>> and that each of these resolves to the same IP.
> 	> And that IP address is probably a load balancer...  I'm pretty
sure
> that
> 	> this single IP thing is not part of the performance measures.
> 	> Traian wrote:
> 	>> But then I decided that this can be worked around
> 	>> by using a file system mount from the web server
> 	>> to the server where the tiles are. I've seen a similar
> 	>> thing done on Linux/Apache, not sure if Windows
> 	>> could handle such a setup.
> 	> I've done this with IIS (CIFS share) and, while I can confirm
that it
> 	> works, it's a pain to set up and the performance is very poor
compared
> to
> 	> local filesystem access.
> 	> While this might be a good solution for some situations (like,
where
> the
> 	> tile servers are behind a firewall?), I think that it would be
best to
> 	> also have the option of being able to set up a local webserver
on the
> tile
> 	> servers to serve the tiles directly to the clients rather than
having
> to
> 	> do everything through the web tier server.
> 	> Jason
> 	> _______________________________________________
> 	> mapguide-users mailing list
> 	> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> 	View this message in context:
http://www.nabble.com/Guestion-about-speedup-mapguide%2C-diferent-domain
name-to-mapagent.fcgi.-tf3307731s16610.html#a9242845
> 	Sent from the MapGuide Users mailing list archive at Nabble.com.
name-to-mapagent.fcgi.-tf3307731s16610.html#a9243857
