[mapguide-users] Fdo2Fdo v0.6.2
Haris Kurtagic haris at sl-king.com
Thu Mar 1 15:13:23 EST 2007
Yes, Fdo2Fdo is free and Open Source. I don't know where it should go (
tools or.. ) but when that decision is made by MapGuide community I will
publish source code also.
Fdo2Fdo is basically two parts: one is UI (Microsoft MFC ) and another
is Fdo2FdoAPI for coping data and that is standard C++ FDO client
application which should be easily portable.
Haris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: 1. marec 2007 17:53
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Fdo2Fdo v0.6.2
Haris, these changes look awesome;  I particularly like the data
inspection tool.
Have you yet to decide whether you would distribute this great tool as
open source or not?  Although I personally prefer using a UI for data
inspection, I'd also really like to see this form the core for an open
source utility for FDO. I think that most of the items which are
available through the UI would also be effective in a cross-platform
command line utility.
It would be great if this could be rolled into the FDO project under
"tools" or something.
Jason
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Thursday, March 01, 2007 06:17
Subject: [mapguide-users] Fdo2Fdo v0.6.2
New version of Fdo2Fdo v0.6.2 is released www.sl-king.com/fdo2fdo
-          Display FDO Class Definition details   Screenshot:
http://www.sl-king.com/Fdo2Fdo/screenshots/FdoClassDefinition.jpg
-          Query and Display data     Screenshot:
http://www.sl-king.com/Fdo2Fdo/screenshots/FdoDisplayData.jpg
-          Setup filter when copying data Screenshot:
http://www.sl-king.com/Fdo2Fdo/screenshots/CopyToSDF2.jpg
-          Create and manage KingFdoClass table Screenshot:
http://www.sl-king.com/Fdo2Fdo/screenshots/KingFdoClass.jpg
RoadMap  for 0.7
-          Support for creating FDO schema. Create and define FDO Class,
create and define class properties.
-          To be able to define copy process. Change class name,
properties to be copied, property definition,...
-          Write copy setting into .xml so it can be reused
-          Run copy from cmd using .xml configuration
I would like to hear your  ideas/whishes.
Haris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070301/76b7bf29/attachment-0001.html
