[mapguide-users] Fdo2Fdo v0.6.2
Greg Boone
greg.boone at autodesk.com
Thu Mar 1 16:01:30 EST 2007
Hi Harris,
I recommend submitting the Fdo2Fdo code to
https://osgeo.org/svn/fdo/trunk/Utilities/Fdo2Fdo
Greg
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Thursday, March 01, 2007 3:13 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Fdo2Fdo v0.6.2
Yes, Fdo2Fdo is free and Open Source. I don't know where it should go (
tools or.. ) but when that decision is made by MapGuide community I will
publish source code also.
Fdo2Fdo is basically two parts: one is UI (Microsoft MFC ) and another
is Fdo2FdoAPI for coping data and that is standard C++ FDO client
application which should be easily portable.
Haris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: 1. marec 2007 17:53
Haris, these changes look awesome; I particularly like the data
inspection tool.
Have you yet to decide whether you would distribute this great tool as
open source or not? Although I personally prefer using a UI for data
inspection, I'd also really like to see this form the core for an open
source utility for FDO. I think that most of the items which are
available through the UI would also be effective in a cross-platform
command line utility.
It would be great if this could be rolled into the FDO project under
"tools" or something.
Jason
_____
Kurtagic
Sent: Thursday, March 01, 2007 06:17
Subject: [mapguide-users] Fdo2Fdo v0.6.2
New version of Fdo2Fdo v0.6.2 is released www.sl-king.com/fdo2fdo
- Display FDO Class Definition details Screenshot:
http://www.sl-king.com/Fdo2Fdo/screenshots/FdoClassDefinition.jpg
- Query and Display data Screenshot:
http://www.sl-king.com/Fdo2Fdo/screenshots/FdoDisplayData.jpg
- Setup filter when copying data Screenshot:
http://www.sl-king.com/Fdo2Fdo/screenshots/CopyToSDF2.jpg
- Create and manage KingFdoClass table Screenshot:
http://www.sl-king.com/Fdo2Fdo/screenshots/KingFdoClass.jpg
RoadMap for 0.7
- Support for creating FDO schema. Create and define FDO Class,
create and define class properties.
- To be able to define copy process. Change class name,
properties to be copied, property definition,...
- Write copy setting into .xml so it can be reused
- Run copy from cmd using .xml configuration
I would like to hear your ideas/whishes.
Haris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070301/4e8c2f99/attachment.html
